FOGLIGHT HELP!
FOGLIGHT HELP!
hello guys!! i need HT help.
i put in factory style fog lights in my 92 EG. i turn them on and they work fine for like a minute or two then the fuse in the engine bay blows. i searched ( i know the search rules ) and the stuff i found on search didnt help me.
i checked the ground connections, both of them.
i bought a new relay.
i searched wireing for tears.
what could be the problem? the relay makes the clicking sound when i turn them on and off. and they work for a good minute. i hope you guys could help me cuz i really been dying to use them....theyve been on the car for like a month
Re: FOGLIGHT HELP! (MARDC5R)
i had this problem once,, turned out that when i changed the bulb the wire on the bulb touched a ground and would pop a fuse..
where did you put the fuse box plug in, maybe thats your problem. or wat u should do is take all the wireing out and reinstall it properly. make sure you dont pinch wires. try and keep trying. i know they came with directions...they help. good luck.
Re: FOGLIGHT HELP! (JDM_Gsr-Si)
JDM_Gsr-Si i pluged them in to number 2, per a "how to" i found here on HT. i have since tried it in other slots...is that right???
i'll take the bumper down tommorow and try rerunning all the wireing and take a look at the wiring near the bulb/fog housings....
thanks guys!!!
thanks guys!!!
Re: FOGLIGHT HELP! (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">i had this problem once,, turned out that when i changed the bulb the wire on the bulb touched a ground and would pop a fuse.. </TD></TR></TABLE>
this is a very common thing that happens...make sure u dont pull on the positive and negative wires too much when install..
91sedan_kid
08-11-2023 11:38 PM
