CRV Gauge cluster question.
Some of you might remember that I bought a CRV gauge cluster to put in my civic.
When I went to install it, I noticed that the plug for my A/T gear selector, Gas level and engine temperature was missing... like the entire unit is missing.. Logic says to go and buy another cluster that has the part.. but i'm not trying to spend another 100 bucks or so. how do I get that part working? what is that part called so I can try to look it up? Should i just give up and buy another cluster?
i need your advice guys, thanks!
Re: CRV Gauge cluster question. (DxBurnoutKing)
Do you have an auto or no?
The gas and temp gauges get their signal from the other two plugs, the only one you'd be missing if the auto plug if you don't have an auto.
I do have an auto...
I plugged in what I could (the 2 blue plus at the top and one yellow one in the back (leaving a green plug empty and of course having the other green one missing for the gear selector indicator) and the temperature needle didnt change.
Re: CRV Gauge cluster question. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote"> 78130-S10-A02 METER ASSY., FUEL & TEMPERATURE $69.78
ok i browed for about 30 minutes and I cant find that part anywhere on the site.. what category are you looking under.
If you have an auto and the cluster is an auto than the shift indicator assembly should swap over from your original cluster.
Btothe3rdDegree
08-10-2004 03:37 PM
jdmintegra1994
11-07-2003 06:22 AM
