oops
Re: (twinloop)
There arent too many places online (that i know of) that sell any GSR shortblocks, your best bet would be the HondaTech Market place. Least i can find anywhere are All sorts of B18 longblocks.
Re: (twinloop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">b18c3? Go back outside and re-read that motor block code again.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinloop »</TD></TR><TR><TD CLASS="quote">euro gsr B18c3</TD></TR></TABLE>
pwned
pwned
Re: (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 »</TD></TR><TR><TD CLASS="quote">
pwned</TD></TR></TABLE>
LOL @ my own humility.
I wasnt aware of the euro versions of the GSR motor
any difference in power to USDM and JDM gsr's?
Ek Forever y0!
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wikipedia »</TD></TR><TR><TD CLASS="quote">
B18C3
* VTEC
* Found in:
o 1995-1998 Acura Integra Type R
* Power: 195hp </TD></TR></TABLE>
It exists
B18C3
* VTEC
* Found in:
It exists
Re: (97Ej6mike)
any difference in power to USDM and JDM gsr's?</TD></TR></TABLE>
http://en.wikipedia.org/wiki/Honda_B_engine
Sorry, key got stuck. I wasn't implying that you should search or anything.
Re: (97Ej6mike)
B16A
Note: All j.d.m. B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
VTEC
Found in:
1989-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1991 JDM Honda CRX SiR (EF8)
1989-1991 JDM Honda Civic SiR/SiRII (EF9)
Displacement: 1595 cm³
Compression: 10.2:1
Rod/stroke ratio: 1.74
Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
Transmission: S1/J1/Y1/A1/YS1
1992-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
Compression: 10.4:1
Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
Transmission: S4C
1992-1995 EDM Honda Civic VTi
Compression: 10.4:1
Power: 158 hp @ 7600 rpm & 116 ft·lbf @ 7300 rpm
1992-1996 JDM Honda CR-X del Sol SiR
Compression: 10.4:1
Power: 158 hp - 170 hp & 111 ft·lbf - 116 ft·lbf
B16A1
VTEC
Found in:
1989-1991 EUDM Honda CRX 1.6i/VTi (EE8/ED)
1990-1991 EUDM Honda Civic 1.6iVT (EE9)
Compression: 10.2:1
Power: 160 hp (112 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 8200 rpm
B16A2
VTEC
1992-2000 Honda Civic EDM VTi (EG & EK)
Compression: 10.2:1
Power: 160 hp @ 7600 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
Transmission: Y21
1999-2000 Honda Civic Si (EM1)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 8200 rpm
Transmission: Y21 S4C
1996-1997 Honda Del Sol VTEC (EG)
Compression: 10.4:1
B16A3
VTEC
Found in:
1994-1995 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
Transmission: Y21
Redline: 8200 rpm
B16A6
VTEC
Found in:
1996-2000 Honda Civic - South Africa VTEC (EK)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7800 rpm & 160 N·m @ 7400 rpm
Transmission: Y21
B16B
VTEC
Found in:
1997-2000 Civic Type-R[EK9]
Compression: 10.8:1
Bore: 81mm
Stroke: 77mm
Power: 185 hp (137 kW) @ 8200 rpm & 118 ft·lbf (160 N·m) @ 7500 rpm
Transmission: S4C With LSD
B17
B17A1
VTEC
Found in:
1992-1993 Integra GS-R (DB2)
Displacement: 1678 cm³
Compression: 9.6:1
Power: 170 hp @ 7600 rpm & 117 ft·lbf (159 N·m) @ 8000 rpm
Transmission: Cable~ YS1
B18
non-VTEC
Found in:
1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
1986-1989 Accord EXL-S/EX-S (Japan)
1986-1989 Vigor MXL-S (Japan)
Displacement: 1834 cm³
Compression: 9.4:1
Bore: 81 mm
Stroke: 89 mm
Dual Keihin Carbs
Power: 160 hp (97 kW) @ 6100 rpm & 128 ft·lbf (164 N·m) @ 4700 rpm
Transmission: A2N5, E2N5
This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
Non-VTEC
Found in:
1990-1993 Acura Integra usdm "rs/ls/gs" DA
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Programmed fuel injection
Power: 150bhp @ 6000 rpm & 121 b/ft @ 5000 rpm
B18B1
Non-VTEC
Found in:
1994-2001 Acura Integra "RS/LS/GS" (DC4/DB7)
Displacement: 1834 cc
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
142 hp @ 6300 rpm & 127 ft·lbf @ 5200 rpm
Transmission: Y80/S80
B18C
VTEC
Found in:
JDM Spec Honda Integra ITR
Power:
200ps (200 hp) @ 7800 rpm
134 ft·lbf @ 6200 rpm
Transmission Type: 5-speed standard
Displacement: 1797 cm³
Compression: 11.1:1 (JDM) - The USDM Integra Type-R 10.6:1
Bore: 81 mm (3.189")
Stroke: 87.2 mm (3.433")
Rod Length: 137.9 mm (5.429")
Rod/Stroke Ratio: 1.58
Transmission: Y80
B18C1
VTEC
Found in:
1994-2001 Integra GS-R (DC2 & DB8)
Compression: 10.0:1
Power:
170hp @ 7600 rpm
128 ft·lbf @ 6200 rpm
Transmission: S80
B18C3
VTEC
Found in:
Power: 195hp
1994-1995 Acura Integra GS-R EURO
B18C4
VTEC
Found in:
1996-2000 UK Civic 1.8i VTi 5-door Hatch
1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon
1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon
1998-1999 EU Civic 1.8i VTi 5-door Hatch
Compression: 10.0:1
Power: 180 hp (124 kW) @ 8300 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
Transmission: S9B
0/100km/h : 7.8 seconds (8.0 Areodeck)
B18C5
VTEC
Found in: USDM DC2 Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Compression: 11.0:1
Power: 210 hp @ 8000 rpm & 130 ft·lbf (176 N·m) @ 8900 rpm
Transmission: S80 w/LSD
B18C6
VTEC
Found in:
1998-2001 Honda Integra UK and Euro Spec Type R
Power: 190 hp (141 kW), 187 Nm
B18C7
VTEC
Found in:
1996- Honda Integra Type R (Australia)
Power: 190 hp (141 kW), 136 ft·lbf
VTEC
Found in:
Compression: 10.2:1
Compression: 10.4:1
Transmission: S4C
Compression: 10.4:1
Compression: 10.4:1
B16A1
VTEC
Found in:
Compression: 10.2:1
B16A2
VTEC
Compression: 10.2:1
Transmission: Y21
Compression: 10.2:1
Compression: 10.4:1
B16A3
VTEC
Found in:
Compression: 10.4:1
Transmission: Y21
Redline: 8200 rpm
B16A6
VTEC
Found in:
Compression: 10.2:1
Transmission: Y21
B16B
VTEC
Found in:
Compression: 10.8:1
Bore: 81mm
Stroke: 77mm
B17
B17A1
VTEC
Found in:
Compression: 9.6:1
B18
non-VTEC
Found in:
Compression: 9.4:1
Bore: 81 mm
Stroke: 89 mm
Dual Keihin Carbs
B18A1
Non-VTEC
Found in:
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
B18B1
Non-VTEC
Found in:
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
B18C
VTEC
Found in:
Power:
Transmission: Y80
B18C1
VTEC
Found in:
Compression: 10.0:1
Power:
170hp @ 7600 rpm
Transmission: S80
B18C3
VTEC
Found in:
Power: 195hp
B18C4
VTEC
Found in:
Compression: 10.0:1
Transmission: S9B
B18C5
VTEC
Compression: 11.0:1
B18C6
VTEC
Found in:
B18C7
VTEC
Found in:
Inisharu D
06-15-2004 04:22 PM
