aem v2 (strange sound)
i put my aem v2 last night and it makes a funny sound that kinda sounds like my tire is rubing on somthing.does anyone els hear that with there aem v2?
Re: aem v2 (Winlight)
Maybe its a coincidence? Check to make sure your wheel well covers (splash guards) arent falling out or something. Also make sure theres nothing obstructing the filter (plastic, leaves, wrappers?) look to make sure theres nothing left inside the induction tube itself.
Re: aem v2 (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Maybe its a coincidence? Check to make sure your wheel well covers (splash guards) arent falling out or something. Also make sure theres nothing obstructing the filter (plastic, leaves, wrappers?) look to make sure theres nothing left inside the induction tube itself.</TD></TR></TABLE>i dont have wheel well covers,and i just pulled the filter off and looked insode and there was nothing in there.also checked inside the pipeing and there was nothing there either.im thinking it might be the fact that the intake pipe hits my tranny line mount on my frame rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight »</TD></TR><TR><TD CLASS="quote">i dont have wheel well covers,and i just pulled the filter off and looked insode and there was nothing in there.also checked inside the pipeing and there was nothing there either.im thinking it might be the fact that the intake pipe hits my tranny line mount on my frame rail.</TD></TR></TABLE>
Could be , id think you would know that right away. the V2 should have a mounting brack that holds it up by the strut tower, that would keep it from touching/rattling against things.
Re: aem v2 (ke98248)
YEA..he;s right i bought a'00 si with I/H/E. It has a AEM short ram intake and it wistles when you give more than 25% throttle. You sure the tire noise isn't from ur tires dude?
Re: aem v2 (babolatplaya)
i put a piece of ruber where it was hitting between the intake and the bracket and now it sounds a lot better.now it just pulsates
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight »</TD></TR><TR><TD CLASS="quote">i put a piece of ruber where it was hitting between the intake and the bracket and now it sounds a lot better.now it just pulsates</TD></TR></TABLE>
Sounds like you solved your own problem
Btw, are you sure you bought the correct intake, for example, not a GSR intake, because the manifolds TB position is different between some B series.
Btw, are you sure you bought the correct intake, for example, not a GSR intake, because the manifolds TB position is different between some B series.</TD></TR></TABLE>i baught the one for the 92-95 civic
daddymaxx
23
11-07-2003 07:01 PM
