What color is the positive wire going into the fuel pump on a 94 Civic Coupe EX?
I have searched, as well as looked for wiring diagrams--- I'm justcurious what color is the stock wire that leads to the power of the fuel pump?? Someone should know surely =/. (notme) =p
There is the main one that is over the fuel pump on the lid, which I would assume is it--- Black wire & Green with a yellow stripe (assuming the obvious) is this correct? Because there is the other connector in the same loom that goes to the body portion with a pos/neg connection as well... it has to clear hard plastic ***** at the end of it? I can take a picture if it would help =/
Re: What color is the positive wire going into the fuel pump on a 94 Civic Coupe EX? (99ssinoc)
I just had some issues with this, so I know for a fact that the yellow/green wire was the hot wire.
There's four wires back there, two for the fuel pump and two for the fuel level sensor (I believe). Easy enough.
One way to check, if you can find a diagram of the main relay, you can follow that green/yellow wire back to the pump. However, on mine I thought it was yellow with a green stripe... But either way, same thing.
SuicideSlide
02-17-2005 03:09 PM
