HELP ASAP.
HELP ASAP.
ok so i just noticed on my car that when my low beams or high beams are on my blinkers click but they dont light...also when my cluster light is on and i turn the light control thingy (the one that turns ur top light on or off when ur door is open)
my buddie says it might have something to do with grounds...but i dont know where to find common grounds on my car (98 civic hatch)...i have some cel's MAP SENSOR...RPM SENSOR... any help on how to fix anything is greatly appreciated
Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">yhea i checked all my bulbs and...i recently wire a new pioneer stereo...but this was going on before the stereo so iono </TD></TR></TABLE>
wth!?
what other cel's do you have? just those two?
wth!?
Re: (krazyhmongboi)
i have RPM FLUCTUATION sensor,RPM sensor, o2 Sensor, TPS sensor,
just havent had time to get around to them... but could that have anything to do with it?
Re: (Kornboy2989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kornboy2989 »</TD></TR><TR><TD CLASS="quote">hak,mjfhjkhfdhfsdhhjgjnsfhfghsdhsh </TD></TR></TABLE>
gredgfglhhgohfarj?
Perhaps the gauge cluster itself?
I'm not too confident on my answer because I have never experienced this kind of problem.
Try using another friend's gauge cluster to see if this problem still persists.
gredgfglhhgohfarj?
Re: HELP ASAP. (Kornboy2989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kornboy2989 »</TD></TR><TR><TD CLASS="quote">yhea thats wut mah buddie says where can i get one of those manuals </TD></TR></TABLE>This thing will pay for itself VERY quickly...
http://www.helminc.com/helm/pr...QA7V8
It has everything you need. You can buy this thing and sound like a freaking GURU... If you know how to read!
Don't forget to use a MultiMeter to check your Fuses. Other than that, it'll be a good idea to iron out all of your electrical issues (including some CELs) BEFORE installing new components. There are plenty of people in the A/V/S Forum who can help determine how much, if at all, your Stereo Wiring is coming into play, but you have to be very specific about the nature of your problem and the Components involved... Be warned, or be warmed (via flame)...
Hope this helps!
JasonGhostz
Hope this helps!
JasonGhostz
ef8powr91
10-23-2006 06:24 PM
lakerschamp2000
Acura TL, RL & ZDX
07-30-2003 06:35 AM
