obdo b16 in a delsol
i got a obdo b16a engine and i want to swap it into my 93 delsol.. i got the sohc vtec engine in it now. can i use my sohc engine harness on the b16 engine?
Re: obdo b16 in a delsol (jonathan13)
i thought so, but the only thing i have to change on the b16 is the alternator and the distributer right?
1 Post
Re: obdo b16 in a delsol (94integra00)
depends, If you have a obd1 del sol the obdo alternator has the same plugs. If you are obd2 you need a obd2 alt or just swap the voltage regulator to the matching connector. You also need to get a obd1/2 dizzy and obd1/2 injectors
Re: obdo b16 in a delsol (Crx Jimmy)
my delsol is obd1.. so i can use the alternater... can i use the sohc distributer? or do i have to get a b16 distributer?
but deffinitly the sohc harness will work on it, just have to change those 3 things and the motor will work as a obd1 right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonathan13 »</TD></TR><TR><TD CLASS="quote">uh yes you can</TD></TR></TABLE>
well you can but your gonna have to modify it...
but i believe he wanted to know if it is a straight plug and play job
