installing ac in my cx hatch
hey whats up guys i just bought an entire air conditioning set-up for my 93 cx hatch. it came with everything that i need, and i know i need to install the (dont know name but have it) under the dash in order to run the lines throught the firewall into it. my question is do i have to remove the entire dash to do this or can i just remove the glove box assembly? thanks guys
i have searched and havent found the answer
Re: installing ac in my cx hatch (nsxmatt)
do you think i should just remove the whole thing then? i have never done it before but i will figure it out if necessary
thanks
thanks
Re: installing ac in my cx hatch (alex_s817)
removing the dash is not hard at all. Just be carefull and remove all the bolts. If you pull on the dash and it doesnt want to come out there is probably a bolt somewhere that you have to remove. You dont want to brake your dash do you.
Edit: yes remove the whole dash, it will be much easier. DL
Just go to a Honda dealer and ask parts or service for install instructions for the A/C kit which is what went into most every 92-93 since they did not come from the factory with A/C. That will tell you how to install it.
dns92civhatchcx
02-05-2013 06:43 PM
Halive
11
07-06-2002 10:49 PM
