Exhaust leak on resonator?
Old 06-30-2007, 10:40 AM
killaj12's Avatar
Default Exhaust leak on resonator?
Hi,
I'm currently running a greddy evo2 on my 00 si
i was told i developed a leak on the resonator ...
is there a way to just patch the hole?
Or should I replace the entire resonator
how much would it cost to replace?
Please help, i want to fix this problem asap.
Thanks
Old 06-30-2007, 11:18 AM
slowcivic2k's Avatar
Default Re: Exhaust leak on resonator? (killaj12)
Depends on how long it has been leaking, and where the break is, I would get your car on jacks and look for black soot coming from the pipes, that will help you pinpoint your exact leak. If it has been open for a while, it may have begun to rot out, so a visual is a must.
Old 06-30-2007, 12:20 PM
Richard...'s Avatar
Default Re: Exhaust leak on resonator? (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Depends on how long it has been leaking, and where the break is, I would get your car on jacks and look for black soot coming from the pipes, that will help you pinpoint your exact leak. If it has been open for a while, it may have begun to rot out, so a visual is a must.</TD></TR></TABLE>
cut the resonator off and weld new pipe in it's place thats what i would do!
Old 06-30-2007, 03:48 PM
killaj12's Avatar
its probably been at least six months since i developed the leak..
if its rotted out, does it affect flow?
or just the sound?
how can i tell if it's rotted out?
what visual cues should i look for?
Old 06-30-2007, 04:40 PM
MidwestCivic's Avatar
it will affect flow, even a pin hole will affect it. This is why I hate the exhaust.
And even worse, the Pin hole leaks show up only under heavy load (in 4th gear @ 2krpms 30% throttle for instance)
This is why you need to visually inspect every inch, or even spray deep creep into the Throttle body, have somebody check underneath for any sign of white smoke. I would put a towel to "slightly" cover up the tailpipe so the leaks will expose themselves.
Easiest is to replace the section IMO.
dvlsfan30
10-14-2008 12:34 PM
OBDII Integra
10-18-2007 09:17 AM
lmfdjtiko
Honda Civic (2006 - 2015)
06-08-2007 12:18 PM
boosted ek
22
02-16-2005 02:08 PM
littledan
12-24-2004 11:24 AM
Quick Reply: Exhaust leak on resonator?
