Gsr Swap Need???
Old 03-01-2010, 03:46 PM
Default Gsr Swap Need???
im planing on putting a gsr swap in my eg what are all the gaskets and fluids that i need
wingzero90 is offline
Old 03-01-2010, 04:04 PM
Civicfanatic_09's Avatar
Default Re: Gsr Swap Need???
Is it a complete swap, why would you need gaskets? Maybe a exhaust manifold gasket, coolant, Honda MTF for the transmission, and I would change oil and filter.
Civicfanatic_09 is offline
Old 03-01-2010, 05:46 PM
318 Curves, 11 miles
Vindicator9000's Avatar
3 quarts honda MTF, 4.25 quarts 5w30 oil, 2 gallons antifreeze, 2 gallons distilled water.
Don't need any gaskets unless you want to replace them. If so, you'll need whatever gaskets you feel like replacing.
Vindicator9000 is offline
Old 03-01-2010, 06:23 PM
Also a muffler bearing so you wont get any exhaust leaks
es01civy is offline
Old 03-01-2010, 06:51 PM
Don't forget the kanuter valve. It is very important.
Old 03-02-2010, 05:10 AM
Information Leafblower
bluebomber's Avatar
KaleCo has a great deal on muffler bearings right now, too!
http://kalecoauto.com/index.php?main...products_id=10
It might also be time to change your clutch belt, so don't forget to check that.
bluebomber is offline
Old 03-02-2010, 10:19 AM
yeah its a complete swap and getting a new exhaust system as well
want to change trans fluid
also any one know where to get shifter brackets,bushings
Old 03-02-2010, 10:23 AM
Old 03-02-2010, 10:32 AM
hbhonda's Avatar
You are going to need the gsr rear tranny L bracket for the motor mount.
hbhonda is offline
Old 03-02-2010, 10:38 AM
Energy suspension makes shifter bushings that are polyurethane. That's what I would use if I was you. Here is an Ebay link to red ones they are like 10 bucks plus shipping.
http://cgi.ebay.com/ebaymotors/Energ...Q5fAccessories
Old 03-02-2010, 10:48 AM
LOL
97hxkidd is offline
Old 03-02-2010, 11:01 AM
Master Detailer
98civdx's Avatar
everything you need can come from a integra
98civdx is offline
Old 03-02-2010, 12:04 PM
il go pick up the kanuter valve, when i go pick up the flux capacitor and the 710 cap
Castillo847
10-03-2009 06:42 PM
spontaneous ep3
08-26-2004 08:41 PM
asianalpha
07-26-2004 07:00 PM
projecthybrid04
12
10-30-2002 03:34 PM
Chugger
05-26-2002 07:07 PM
Quick Reply: Gsr Swap Need???
  • Ask a Question
Question Title:
Description:
