Shift Linkage Bolt Snapped... Help
i made the mistake of using a snap-on 3/8 rachet on the shift linkage bolt that goes into the tranny and it snapped... any suggestion on repairing it...
THIS IS THE BOLT
THIS IS THE BOLT
Re: Shift Linkage Bolt Snapped... Help
i say.....drill the bolt out, and then get one of those tools to remove it, and then buy the correct bolt.
look around on the hondaautomotiveparts.com website, you'll find it.
if the bolt has some sicking out still try a little heat with a visegrip and tap on it as you back it out if you drilll it plan on re-tapping the threads
no, you drill a small hole in the stud, then get one of those tools that you screw into the hole, then you can unscrew the broken stud with the tool.
eM1_kiD
09-29-2013 08:10 PM
