gsr burning oil
gsr burning oil
Well my 97 gsr is burning oil I'm going to get a compression test soon ice herd I have to rebuild the engine and I herd I just will have to do the piston rings and valve seals any advise you guys can give me would help a million
Thanx
Thanx
Re: gsr burning oil
if your just doing the pistion rings its kinda of a waste, you might as well get everything rebuilt while your in the block. You can always just send the head in to a machine shop and have them replace valve seals which wouldnt be that expensive.
Re: gsr burning oil
yep, go ahead and send the head in and get the stem seals replaced or ur gona still be leaking oil. get a 3 angle done on it also. check the walls and make sure u have no scuffing. all gaskets and seals. and u may wana just go ahead and change the bearings out also.
318 Curves, 11 miles
Re: gsr burning oil
How much oil is it using?
Every Honda I've ever had seems to go through about 1/2 quart every 3K miles, even when they were new... My 00 Civic did it when I bought it with 7K miles on it. It seems like my GSR tends to use more if I'm in vtec more.
If it's that much or less, I wouldn't worry about it much.
If you really want to figure out the problem without a complete rebuild, I think you need a leakdown test. It's the only way you'll find out if it's rings or valve seats.
Re: gsr burning oil
mm it burned prolly almost 2 qt in 2 months or so and whats a leak down test ive been trying to research on this and only found ppl saying do a compression test
and NO i dont want to rebuild the whole motor cuz i aint got baller fundz lol
Re: gsr burning oil
so if i bought a set of type r piston+rings could i put them on my gsr rods and if i got valve seals that would stop the burning oil problem
Crazy Honda Guy
Re: gsr burning oil
I wouldn't bother with Type R pistons, go with something like a P30 B16 piston set with rings. And yes, new valve stem seals would a wise decision.....engine should run like new, and with the higher compression, you'll make more power
Crazy Honda Guy
Re: gsr burning oil
B16 pistons have always made more compression
http://www.c-speedracing.com/howto/c...c/compcalc.php
Re: gsr burning oil
thanx for that link lol u can see diff combos and your right lol i just assumed type r would yeild the most torq but i assumed wrong ha
