no power when taking off
Guys I have a 98 civic ex and when I take off in the morning in first gear the car just falls on its face . It runs fine when just sitting and reving it. If I let it warm up for awhile the problem goes away.
Any ideas?
Any ideas?
Re: no power when taking off
The most common cause of this is an intake manifold vacuum leak. You can check for this by testing the MAP sensor signal voltage and/or by spraying starting fluid on the leak. If you spray starting fluid on an IM vacuum leak, it will change the idle, usually causing it to rev up a little. Another possibility would be a bad or dirty FITV.
sounds familiar.. what happen to mine was the distributor somehow one of the bolts got loose and i was told mis aligned right after they fix it i got my power back.. i suggest also tune-up or your tranny is going bad...
Do you have an automatic or manual transmission? If you don't find any vac leaks and you have an automatic, you might have a transmission issue. It seems like it should throw a code if the problem is in the a/t, though.
asianrepnsb
12
03-08-2008 12:26 PM
