2000 acura el ENGINE MOUNTS NEED HELP ASAP
hey everyone i got a quick question.
I recently purchased a 2000 acura el 1.6 automatic
i have a b18c5 98 spec with tranny mounts axels shiftlinkage ecu
I am going to install the clutch pedel and master cylinder for the swap.
my question is what motor mounts do i use to put a b18 in and will my shift linkage work?
will my itr wireing harness work?
will my axels work?
anything i should know about before i go into this swap?
any help anyone can give me is greatly appreciated.
thanks agian from canada eh!
will my axels work?
Re: 2000 acura el ENGINE MOUNTS NEED HELP ASAP
For mounts you use D-series transmission body mount and bracket, D-series rear body mount with 1999-2000 SIR "T" bracket, D-series timing belt body mount with 1999-2000 SIR post on the block. Use your D-series harness and add wires if necessary. You may also need and OBD2a-OBD2b conversion harness before the computer. Axles you use from the 1999-2000 SIR. Shift linkage also from the 1999-2000 SIR. You can also search and find tonnes of info as your car is the same as any "EK" civic.
[B]I NEED HELP I HAVE A EF8 SIR FRONT CLIP CONVERTION WHAT MOUNTS DO I NEED TO USE TO DO A BERIES SW
jdmrhdcrx
12
02-15-2006 08:36 AM
Monty
10-04-2002 07:22 PM
Monty
04-30-2002 02:33 PM
