E85..is it good
E85..is it good
im running a slap on jdm itr stock all motor just ngk wires and pulse start plugs...is it better to run e85 vs 92 octane? do i have to switch anything as of injectors etc. to run e85 -thanks
Re: E85..is it good
you should not run e85 on that setup.
if you where boosted, yes, but you would need bigger injectors, fuel pump, and replace your lines so the E85 dose not caroad them away.
any reason that you are looking at swapping to e85?
Re: E85..is it good
just got done with the swap and still runnning with gas i had left in the car which i believe it was 92 octane (premium) , and o yea also gotta 225 walbro fuel pump..any reasons why e85 is better. what i heard was "because it contains oxygen. C2-H5-O-H is the molecular formula for ethonal."
Wasabithegosu
05-25-2005 03:55 AM
CrOmEdOmEcHaMbEr
10
05-09-2002 11:41 AM
