00 civic si barely moves no power help!
Ok i was driving home my cel came on for code 4 which is a ckp (crank position senor) went into limp mode wouldnt go past 3.5k rpm.. So i found out the sensor is located in the dizzy replaced that and now they cel is off revs past 3.5k but has no power at all.. when i press the gas the car just bogs out and barely moves at all.. i have to ease on the gas to get it to go... Any ideas what to check???
What i have done:
spark plugs and wires less than 10k mi ago
new cap
adjusted the dizzy every which way dosnt help
double check the firing order
what else could it be??
What i have done:
new cap
Re: 00 civic si barely moves no power help!
the distributor i just got has tc-08a marked on it.. looked the number up and it says its only for 1.8l bseries engines could b the reason??
318 Curves, 11 miles
You have NO CEL, and it's still in limp mode?
I would re-scan it and see if it still has anything stored. I can think of no reason that a Civic would limp mode with no CEL at all.
no the car dosnt have a cel on.. im not for sure car is n limp mode or not it just moves REALY slow i have to ease on the gas to get it to move
MrXclusivE
11
01-14-2010 01:15 PM
supercoy101
14
06-07-2009 10:46 AM
