Temperature drop...
Temperature drop...
when my car warms up the temperature is normal the needle stays in one place. ill continue to drive for a little and the temperature will drop down... doesnt make sense obviously cause engines dont get cooler when there runnin longer.. i thought it was my cluster. so i replaced it and same thing happens the needle just drops after a period of time then will go back up randomly.. any suggestions? thanks
Re: Temperature drop...
its probably just the thermostat opening and closing depending on how far the needle drops it seems like normal oporation to me ..thermostats are pretty cheep n easy to replace ..............or check to see if your radiator fan stays on all the time that could promote to abnormal cooling characteristics if its the fan it could be a stuck really maybe even a cts problem
agreed on the thermostat.. however with a new thermostat i still get a little bit of needle play during the winter. on top of it taking like 20 minutes to warm up the car
as long as it dropping and not raising ur safe
well, when i first start up my car it runs all the way rich(using a narrowband o2 sensor and gauge) then it slowly goes down to all the way lean, stays there for like 20sec and slowly goes up to optimal, then shoots up to rich and stays there. until im driving at highway speeds for 5-7 minutes itll start to go down to optiml but only when im on the gas. and if i continue at highway speeds it goes leaner and bounces alot between lean and optimal dependin on throttle position.
-2 cents
the a/r ratio is correct its supposed to bounce back and fourth for optimal cat. efficiency also on startup the car is in open loop and isnt getting a proper o2 reading cause the motor and o2 are not warmed up after a certain amount of driving the vehicle will go into closed loop and the gauge will start to fluctuate between lean and rich .....its never gona stay on stoich
i had mine do this one time when i would get on it i guess fluid would push past the thermostat and i replaced the thermostat and this all stopped the lil O-ring int he middle was leaking.
im experiencing similar issues. when cold to warm up, it seems like you say. i have an oil temp gauge(someone gave me) and at 150 degrees or higher. the gauge goes full lean when cruising. after 3k rpm the gauge goes rich. you can feel the transition. whats going on here?
aasaa666
05-31-2010 07:15 AM
jdmspoonitr
10-13-2006 05:10 PM
