Swap budget
Old 06-26-2010, 09:23 AM
Civic483973's Avatar
Icon2 Swap budget
OK i have a b20/vtec im swapping into my eg. I have a tight budget so i was wondering what I HAVE to get and what i dont?? I know i should get the ARP bolts correct? I was hoping i can just open the block up and just grease everything and reassemble it until i am ready to actually build it. So what all is a must to invest in so i dont screw up my swap besides ARP bolts and all my gaskets/timing belt?
Old 06-26-2010, 09:57 AM
Cynical 1's Avatar
Default Re: Swap budget
keep saving...
Old 06-26-2010, 10:28 AM
azandford's Avatar
im confused... do you have the b20vtec ready to go or do you need to build it or what? your post is a bit confusing
Old 06-26-2010, 09:52 PM
i have the b20z motor and GSR head plus GSR trans and its all complete but the block is seperated from the head so i was wondering how important it would be to put new rod bearing s and rings etc? What all do i have to invest in to be on the safe side?
Old 06-26-2010, 10:10 PM
kevinm1981's Avatar
arp bolts would be something that you wouldn't need.
Old 06-27-2010, 05:13 AM
702Prodigy's Avatar
Great info right here!!!! LOL!!!
Check the all motor forum for the thread on building a reliable ls/vtec. That should steer you in the right direction!
Old 06-27-2010, 06:45 AM
ARP bolts are the first thing i need isnt it?
Old 06-27-2010, 03:37 PM
kevinm1981's Avatar
Not if your on a budget. they are not going to do anything the oem ones would not do.
Old 06-27-2010, 04:15 PM
702Prodigy's Avatar
Having the ARP rod bolts is insurance that the motor will be reliable. Stock bolts have known to fail when doing ls/b20 vtec builds when you are revving higher than a stock ls/b20. I guess if you keep the stock ls/b20 redline you should be fine, but why don't you just stay non vtec?
Old 06-28-2010, 09:27 AM
i am going to build the motor but not yet i dont have the money to do a full build right now
PS: what is the stock redline?
Old 06-28-2010, 12:57 PM
kevinm1981's Avatar
for a b20?
Old 06-28-2010, 09:01 PM
yes a b20
Old 06-28-2010, 09:04 PM
kevinm1981's Avatar
around 7k
Old 06-29-2010, 12:41 PM
ok thank you both for your help
Old 06-29-2010, 12:43 PM
t
Old 06-29-2010, 01:47 PM
harms_is_back's Avatar
dont forget to tap the head. the oil lines i would get a block guard and if your save its not that expensive just get some better pistons. and you should be good bro.
Old 06-29-2010, 08:49 PM
ok i have a question on the dowel pins.... they dont look like they will fit to the block
do i have to have anything machined for that or should it just go right in?
Old 06-29-2010, 08:58 PM
hard_boiled_EG's Avatar
x2
Old 06-29-2010, 10:46 PM
LuczOr's Avatar
x3
This is not an easy build, you need to make oil lines for vtec and bore for dowel pins. NO LEGO BUILD HERE.
Old 06-30-2010, 06:37 PM
damn ok so the block has to be machined also for the dowel pins?
i didnt see any info on that forum about borin for the dowel pins but they sure dont slide right on each other. I just saw the part of plugging the head.
noender
09-24-2010 12:39 PM
phan222001
09-04-2009 05:36 AM
mountaindewguy
01-20-2006 01:22 PM
poch915
08-16-2005 01:46 PM
Civichatch2k
12-26-2004 10:32 PM
Quick Reply: Swap budget
