INTEGRA DASH SWAP WITH AC
I SEARCHED NOBODY KNOWSS!!!
i did the integra dash swap in my cx hatch and swapped the b18b from the same integra.everything lights up and works except for my rear window defroster but i dont need that. but i still have not hooked up the ac.i plan on using the complete integra lines as im using the integra evaporator and integra ac compressor and all hardware..now my problem the integra ac harness has 2 more wires on the actual harness itself if i were to use my cx ac harness with all the integra components will it still work with my integra heater ac controls?
has anyone done this before?
i have all components for ac on the integra and cx hatch so i need to find a way to make it work cause the cali heat is here and im not gonna fry driving that car..lmk
thanks in advance for your help
Re: INTEGRA DASH SWAP WITH AC
because i have a integra ac evaporator under my dash because i swapped to a integra dash.civic ac lines will leak on integra ac evaporator...
there in the big plug that plugs over by the headlamp harness civic has 5 wires on the plug integra has 7 wires
