Please help!! Spark Plug won't come out
Old 06-27-2010, 05:13 AM
NOTDISFA5's Avatar
Default Please help!! Spark Plug won't come out
I really need somebodys input on what i can do to get a spark plug out from cylinder 1. Its turned like 2 x when i was unloosening it and then wen back to tight. It looks like it centered right. How can i get this out? can i use wd-40?
Old 06-27-2010, 05:22 AM
D Griff's Avatar
Default Re: Please help!! Spark Plug won't come out
Just go get a tune up at a Honda dealer, let it be there problem. Unless someone knows a better way, I'd like to here it as well.
Old 06-27-2010, 05:30 AM
NOTDISFA5's Avatar
Yea i hear you but i doubt honda will want to be responsible for breaking the spark plug. I heard to run the car for a while so it can heat up and then come out but that didnt work
Old 06-27-2010, 07:47 AM
NOTDISFA5's Avatar
Old 06-27-2010, 07:53 AM
joss731's Avatar
^^^^ prolly the only time id go to the dealer
Old 06-27-2010, 10:18 AM
NOTDISFA5's Avatar
Alrite guys i got them out. There were two bad ones. I never thought i can spray anything into where the spark plug goes but the guy at autozone said i can spray this spray called Freeze-off and it worked. It just took a long time and patience.I just hope all that stuff i sprayed doesnt mess up the engine
Old 06-27-2010, 10:54 AM
BlueIntegraBoy's Avatar
Put some anti-seize on when you install new plugs.
Old 06-27-2010, 11:02 AM
D16SiHatch's Avatar
when the plug finally came out did it look like it took some thread material with it, or was it fairly clean?
Old 06-27-2010, 11:37 AM
H-T White Ops
NOFX's Avatar
If you buy your plugs at Autozone, they have little packets of antiseize behind the counter.
We're supposed to offer antiseize to people when they buy spark plugs, but people always say they have some at home. $1.19 plus tax is definitely worth not having your plug stick.
Old 06-27-2010, 12:02 PM
D Griff's Avatar
It shouldn't mess up the engine, if it got in it'll just burn away.
ravinaziankid
08-14-2012 05:25 PM
TQuach
11-24-2005 10:28 PM
hmtcrxsir
10-16-2005 05:51 AM
arielb1
07-24-2004 10:24 AM
integra93
12-30-2003 04:17 PM
Quick Reply: Please help!! Spark Plug won't come out
