Antenna Delete Plate
Old 06-28-2010, 12:40 PM
JPerkMr954's Avatar
Default Antenna Delete Plate
I'm tired of seeing my antenna on my car so I found that Honda has an OEM delete plate. How exactly do you use this? Its it pulled out and then you cover it? Does the antenna go into the A-Pillar? If anyone who has done this can tell me how to do this, that would be great!
Old 06-28-2010, 02:00 PM
JDM_SOHC's Avatar
Default Re: Antenna Delete Plate
I stuffed the antenna into the hole and put the delete plate on, end of story..
Old 06-28-2010, 02:01 PM
Gunmetal_B20_Hatch's Avatar
Yes, just remove the antenna and pull the cable out the top of the car.
Old 06-28-2010, 02:08 PM
JDM_SOHC's Avatar
And be prepared to not have a radio anymore...
Old 06-28-2010, 02:29 PM
Slomo_civic's Avatar
I barely get any radio with the antenna retracted all the way. i usually have to have to have it fully extended to get good signal. I like the looks of the delete but I like the option of listening to the radio more
Old 06-28-2010, 03:07 PM
BlueIntegraBoy's Avatar
I removed my OEM antenna and opted for an aftermarket, windshield-mounted antenna.
Old 06-28-2010, 05:07 PM
Dekorum's Avatar
Hahaha!
OP, you do not want to remove the antenna wires that goes to the back of the head unit. If you unscrew the existing plate with the antenna, then push the antenna down, not too far, then put the delete plate over. Thats it. You will still have perfect reception, if you have a good head unit.
Old 12-06-2010, 05:28 AM
JPerkMr954's Avatar
So you can still get radio, though I never listen to the radio anyway.... With having the delete plate installed? Sweet!!
Old 12-06-2010, 06:39 AM
Red_Army's Avatar
lol or buy an ipod, ipod adapter and a decent head and you can have 10k+ songs at your disposal.
i have radio and haven't used it for 2 years.
Old 12-06-2010, 07:03 AM
foo fighters's Avatar
i removed mine completely and smoothed it over w/ bondo, but i only used my mp3 player anyway cause my antenna doesn't work anymore.
Old 12-06-2010, 07:08 AM
ifIexplode's Avatar
Idk if 5th GEN civics are the same as 6th GEN in this matter, But 96-00 civic have a plug halfway in between the actual antenna and the plug behind the radio/headunit, Its right above the hood release, You can unplug it there and pull it through the A piller with ease.
paniaguae640
07-27-2009 08:28 AM
ke98248
05-31-2007 09:02 PM
prostreetonline
06-02-2006 05:01 PM
prostreetonline
11-29-2005 10:28 AM
Julian
07-26-2002 01:13 PM
Quick Reply: Antenna Delete Plate
