help!
help!
so i got this honda civic 99 si it wont start when i turn on the ignition. i dont here nothing, no cranking no nothing but when i jump start it from under the hood where the starter is with a screw driver it starts up fine and i drive it all over until i turn it off again and i gotta jump it again. this happen just today(6/24) yesterday(6/23) was working just fine..
whats the problem???
thanks in advance
thanks in advance
Re: help!
Without performing diagnostic troubleshooting nobody can tell you what is wrong. From what you say, I would begin figuring out why turning the ignition switch to START doesn't cause the starter to turn.
Check for battery voltage at the starter solenoid in the START position. Trace backward if voltage is not present to find the fault ( Aftermarket alarm? Aftermarket starter cut? ). If voltage is present the starter is probably broken.
Re: help!
Check to make sure you have power at the small wire at the starter with the key in the start position(3rd) you will need help doing this , if not then check fuses or relays under the dash and hood. If you have power then your solenoid on the starter is bad and needs replaced
Jack Murphy
06-21-2017 06:23 PM
elpermgrande
08-09-2002 06:43 AM
