removing ign lock cylinder
I bought a 92-95 civic need to get the lock cyl out becasue the tumblers are bad what is the easiest way any insight would be nice please and thank you?
Re: removing ign lock cylinder
hammer
i kid
if its like most you need to pull off the bottom case of the column and there will be a small hole at the bottom and take a small screw driver or nail and push it in the hole and work the tumbler out
i kid
You need the old key, a small phillips head screwdriver or a nail or something pointy, and a flathead screwdriver or a pair of pliars. You have to remove the trim around the column, put the key in and turn it, push a pin in, pull the cylinder out and lift a hook up.
This isn't for stealing a car as you still need the old key and I'm not sure if it can be done easily with the column in the original position.
Kipper-Fish
11-27-2008 09:17 AM
bsclywilly
Audio / Security / Video
06-02-2007 08:33 AM
