NEED HELP WITH SMOG
NEED HELP WITH SMOG
i'm trying to bar'd my eg6 with a obd1 gsr swap..the motor has been rebuilt and bored .20 over with JDM P30 pistions, skunk2 intake manifold, aem intake and dc headers and an ITR intake cam....with a stock OBD1 P72....the motor has only 200 miles not even broken in yet...on the day of the smog which was at 3:00pm in the afternoon, I wanted this **** to pass so I woke up at 5am and replaced everything that i can think of.., cap, rotor, plugs, wires, pvc valve, o2 sensor and even a brand new cat and also did an oil change as well.....so an hour before i went to the reff...at 2:00 i pumped 91 octane and added an octane booster by lucas and drove around town on the freeway for aboutn 45mins and then i went straight to the reff...and waited 15 mins until he took my car in....and I failed for High HC on the 15mph....... here's what it said on the sheet
timing : 16 btdc
15mph: HC :MAX-90 AVE-21 MEAS-109-----------FAILED
C0: MAX-0.54 AVE-0.06 MEAS-0.16
NOX: MAX-711 Ave-150 MEAS-460
25mph: HC :MAX-56 AVE-13 MEAS-43
C0: MAX-0.53 AVE-0.05 MEAS-0.03
NOX: MAX-754 AVE-136 MEAS-71
and yeah i was pissed...anyhow i came home and check my plugs(NGK single Platium) and they were blacked and wet like they were fouled out....the car is running too rich so if anyone has any ideas please let me know...
timing : 16 btdc
Re: NEED HELP WITH SMOG
Did you try backing off your ignition timing by 1 or two degrees. I think you can go 2 degrees either way? You didn't fail by much.
fm
fm
No check engine light and running stock fuel rail and for the temp was right under half and iam running a stock integra radiator....I talked to a couple people and looks like the only thing that might help is retarding the timing...But I'm just curious why it's running rich..
well i failed on high HC so shouldn't I retard the timing to lean out the car so it won't run too rich... another question is the stock timing should be 14+-2 rite...?? what about the fuel pressure...any idea how much psi and how do you test that...?
You passed visual?? I think your supposed to be bone stock to pass no?? Also, the smog check stations Ive been to always recommend me to put the stock air box and headers... I dont know why if theyre CARB legal....
also yes you can be off by 2 degrees.
putting stock headers and intake wont do much. if they are already carb legal then they run closer to stock specs. well the headers do at least.
i would try a chipped p28 or another ecu. it is possible yours could have been tampered with. unless you opened it and saw that theres no chip burned into it.
now from my experience with BAR and REFF you only have to pass visual now days in cali. smog you do on your own. where you located?
PunkRudeBoy
28
05-22-2013 02:30 PM
efmk4
07-30-2012 05:30 AM
thao4life
03-15-2004 11:03 AM
