Antifreeze
Old 06-28-2010, 05:49 PM
96CivicEXSedan's Avatar
Icon2 Antifreeze
So, I'm just starting out trying to take care of my car. And thanks to everyone so far. I got a lot of help with my power steering thread from a few days ago. Works well. I've also been reading the manual. I hope to progress from novice one day!
Anyways, it appears that my antifreeze/coolant is very low. So that leads me to a few questions:
  1. Does this indicate a possible leak or normal wear and tear?
  2. Is using the Genuine Honda Type 2 50/50 antifreeze the only one I should replace the lost fluid with?
Thanks again.
Old 06-28-2010, 06:16 PM
D Griff's Avatar
Default Re: Antifreeze
If it were me, I would fill it up and check it everyday, see if the level is lowering. Check under the car/around the engine bay so if it is leaking you can figure out where it's leaking from. Hopefully if it is leaking it's just a hose, a cheap, easy fix.
I personally just use Prestone antifreeze or something similar, I'm cheap. I also flush my radiator with tap water and mix the antifreeze with tap (50/50 ratio) if it isn't the premixed stuff. Some guys on here will tell you only to use Honda but I've run Prestone/tap in all of my cars with out any issues ever.
I hope this helps you out.
Old 06-28-2010, 08:52 PM
Thanks. Is it reasonable to think I can find the leak myself? It's filthy in there, and I've been to mechanics who said I had a leak but they couldn't tell where it was.
Do keep in mind that I'm a real novice...
Old 06-28-2010, 10:20 PM
87 SiviK Si's Avatar
You wanna find a leak with a dirty engine bay. Buy a bottle or 2 of simple green, or 2 cans of engine degreaser, take car to a coin op car wash. let engine cool down, spray bomb it, blast it with water. clean Engine bay... time to find leak.
Old 06-29-2010, 09:43 AM
300whpej's Avatar
the honda antifreeze isnt anything special, besides the fact that its blue. i run prestone or the autozone 50/50 with no problems and i run full strength in the winter. my reservoir has a leak and wont hold any fluid, luckily i check my fluids daily and my radiator is holding just fine.
Old 06-29-2010, 05:51 PM
Is the leak because you used the wrong coolant? Just a thought...
Old 06-29-2010, 06:15 PM
Linked's Avatar
on a side note ... blue antifreeze sounds awesome (witha clear overflow bottle or something )
Old 06-29-2010, 06:30 PM
D Griff's Avatar
Now that it's been mentioned, my reservoir tank always seems to be empty. However when I remove my radiator cap, it's full to the brim and the car runs at a perfect operating temperature. This has happened with other cars I've been around as well. If that's the case, it probably isn't worth worrying about.
Cleaning your bay really well is a good way to find your leak!
Old 06-29-2010, 06:33 PM
D Griff's Avatar
Also, I wouldn't recommend running full strength antifreeze (no offense 300whej) unless you're somewhere that gets really, really cold. Water is a much more effective coolant than antifreeze, the antifreeze is there for just what its name implies, so it doesn't freeze, expand, and damage your engine. However, I believe 50/50 is good down to around -30 degrees fahrenheit.
Old 06-29-2010, 07:07 PM
Linked's Avatar
your overflow tank or the tube leading to the neck of the radiator could be leaking or clogged
Old 07-01-2010, 06:49 AM
300whpej's Avatar
no, there is a slit in the bottom of my reservoir, im just too lazy to get another one and change it out.
nek9
18
03-16-2006 06:25 AM
hotsuma23
09-26-2004 03:53 PM
AznJohn33
11-20-2003 10:50 PM
TypeR 599
12-06-2002 11:25 PM
Quik89Si
12
11-18-2002 12:13 AM
Quick Reply: Antifreeze
