gsr full brake conversion or 5 lug conversion??
Guest
Posts: n/a
i have the chance to get a full brake conversion off a 94 gsr front and rear for dirt cheap only problem is i have to take it of my self its wrecked. should i go ahead and get it were talkin about 200 bux. or shold i wait and get the 5 lug brake setup?
Re: gsr full brake conversion or 5 lug conversion?? (hatchboy93)
if every thing is not bent jump on it and sell it later for more then you bought it for
<-------running it on the CX and has to say is on eof the bests mods yet
I would get the GSR stuff if it isn't bent/etc.
5lug is nice but unless you're actually racing and need the wider track and beefier hubs, there aren't too many compelling reasons to go that route. Looks cool, though.
Guest
Posts: n/a
Re: gsr full brake conversion or 5 lug conversion?? (SkyeC)
yea i figured that too. i want to get the gsr brakes but im just so lazy!!!!! i have to pull them off then i have to pull mine off then put the gsr's on i mean i just did my swap and im tired lol
best way to detach the GS-R stuff is take off the 2 17mm bolts that attach the upper front controll arm thru the shock tower, undo the lower ball joint, the steering ball joint, take the axle out of the hub and detach the brake lines. You don't need the front LCAs.
hey buddy if don't want the gsr stuff, i'll buy it off you for like 300. $100 profit just by taking it off the GS-R :D
check everything since it was wrecked...but a nice 4 lug gsr brake conversion is cool..just get some nice fastbrakes rotors and legend calipers
Re: gsr full brake conversion or 5 lug conversion?? (Project H22DC4)
5-lug is nice, but for $200, I say get the gsr setup. However as others have said, make sure that it isn't bent.
Guest
Posts: n/a
Re: gsr full brake conversion or 5 lug conversion?? (purek9hybrid)
ok i went yesterday and pulled the whole brake system off the wrecked gsr, and every thing is still perfect no bent pats. i got the whole rear trailing arms with E-brake cables, and i mean everything lol, and i got the whole front system including the upper A-arm oh i also went aheadn ang gor all 4 struts and springs while i was there the struts are pretty new. i think im going to put them on this weekend one more thing i forgot i am gonna have to go o the junk yard too to pick me up a 40/40 proportioning valve!!!!! after that i should be ok untill i get more money to get that new upgraded master cylinder what do u guys think?
No you dont.
I do have all GSR components on mine, but you can take just the front knuckle piece that attaches at three points and the axle.
I say do it. Its only like an hour to take it all off. I drove a state to get it for more than that. I say go for it.
Guest
Posts: n/a
Re: gsr full brake conversion or 5 lug conversion?? (White Lightnin)
yea but im just so jealous lol at all these other guys with their expensive 5 lug conversions and their sway bars and their mugen this and mugen that. i wish i could afford all that like some of these guys.
good call. if you ever decide to sell it, you can get much more than what you paid. rims are cheaper and there's much more variety for four lug, there are more options for brake and rotor upgrades. etc..
Guest
Posts: n/a
Re: gsr full brake conversion or 5 lug conversion?? (mugen76)
thanx guys. the only bad thng is one of the studs that the lug nut goes on has been broken but im going to tap out the broken stud and replac it with one off my old brake system but i just put in brand new EBC green stuff brake pads and they fit perfectly i cant wait to try them out!!!
Do you grab the booster and mc as well?
Check this out :
https://honda-tech.com/zerothread?id=364783
Check this out :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchboy93 »</TD></TR><TR><TD CLASS="quote">thanx guys. the only bad thng is one of the studs that the lug nut goes on has been broken but im going to tap out the broken stud and replac it with one off my old brake system but i just put in brand new EBC green stuff brake pads and they fit perfectly i cant wait to try them out!!!</TD></TR></TABLE>\
while your at it put in stronger studs! maybe extended but just not skunk2 ive heard bad things bout them...
Good call on not getting the 5lug...i think youll regret it later....money for the "oooh hes got 5lug conv." factor is wasted money IMHO
BE SMART and BUY smart...you can upgrade your gsr brakes to be quite beafy and outperform the 5lug
Guest
Posts: n/a
Re: gsr full brake conversion or 5 lug conversion?? (B18c1CivicTurboed)
i can get the booster and master cylinder from the gsr for free but i didnt think it would work because the car has abs and my car doesnt can i make the brake booster and M/C and the prop. valve work on my car even though the gsr had ABS ?????
Guest
Posts: n/a
never mind guys i know the answer. it wont work because i would have to flare and bend my factory lines to reach it its a hassle in it self im just gonna get that M/C off the 92 4 door civic ex or one off a 92-95 civic SI hatch
no, the best way to do it is with a slide hammer. you cant just hammer it out because there is not enough room. get a slide hammer that attaches to your studs with the lugs and bang that biotch out, it should only take a couple trys.
