Short Shifter rubbing/rattling on exhaust?????
Had a GSR short shifter installed in my 99 SI yesterday and the shifter is rattling on the exhaust. Not very bad but every now and then I hear it. And when they installed it they showed me. Anyone else have this problem or know of a way around it?
Re: Short Shifter rubbing/rattling on exhaust????? (TwistedSI)
its probably hitting a heat shield on your exhaust piping, so just take out the heat shield if thats the problem
thats what happened to my short shifter, they pulled the exhaust down and i also took of the heatsheilds. it solved my problem
Re: Short Shifter rubbing/rattling on exhaust????? (FifthGearOnline)
theres a heat shield there? or supposed to be? when i installed mine it was just the pipe and the heat shield ended about 1.5 feet before it.
I removed the heatshield on mine...no problems at all...'cept the damn thing still rattles now and then...very annoying because Ive tried just about everything...
Re: Short Shifter rubbing/rattling on exhaust????? (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I removed the heatshield on mine...no problems at all...'cept the damn thing still rattles now and then...very annoying because Ive tried just about everything...</TD></TR></TABLE>
Did you double check to see if the shiftlink that is connected to your shifter is tight? Sometimes it is lose and the washer rattles around a little
Re: Short Shifter rubbing/rattling on exhaust????? (gambit33)
yep...in fact I was just under there last week putting in new bushings and I double checked all the bolts as preventative maint.
I think its just cursed
if it's a b&m you have no recourse, they suck *****... and rattle too.
replaced mine with a skunk and its seriously awesome, highly recommended.
Re: Short Shifter rubbing/rattling on exhaust????? (euclid)
The rattle is a common problem for short shifters. It all depends on the individual car whether yours will hit or not. I put one on my car and it rattled, I adjusted the exhaust hanger and it now rattles less. Put on a cat-back exhaust that doesn't have a heatshield and no rattle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">if it's a b&m you have no recourse, they suck *****... and rattle too.
aha...well that would be the culprit then...
Im not gonna change it though...I'll just keep the annoying little f*cker until the swap and then get a better one.
...and all this time I thought it was just me...
i have always seen them hit the resonator, not the heatshield. the shift shifter is longer on the bottom side of the fulcrum point, thus making your shifts shorts, and your shifter rub the resonator.
Re: Short Shifter rubbing/rattling on exhaust????? (Damon)
It also depends on the design of the short shifter. Its all about the length ratio from below to above the ball pivot. The ones that are fairly long on the underside can have problems with the counterweight part rattling on the exhaust. In most cases is when the car still has the stock exhaust.
KHowe
07-31-2007 07:13 AM
Hammett
12
11-28-2001 07:32 PM
