Jack points...please help!
My EG has a bent rad support hence i can't jack the front from there. I am planning to pull the motor out of the car soon so i will have to put it on stands. Is there another jack point from the front which is safe to lift the car by? If not, any other suggestions to put the car on stands? Thanks.
Re: Jack points...please help! (eg-six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg-six »</TD></TR><TR><TD CLASS="quote">My EG has a bent rad support hence i can't jack the front from there. I am planning to pull the motor out of the car soon so i will have to put it on stands. Is there another jack point from the front which is safe to lift the car by? If not, any other suggestions to put the car on stands? Thanks.</TD></TR></TABLE>
so your jack point is bent? or damaged? dont know if this will work..but could you do if from the sub frame? although..its under the engine....?
Re: Jack points...please help! (kent)
Mine is messed up too so i use the transmission as a point to lift it. Works great and doesnt mess it up at all and you could get it high enough to put jacks on the side then let go. Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kent »</TD></TR><TR><TD CLASS="quote">
so your jack point is bent? or damaged? dont know if this will work..but could you do if from the sub frame? although..its under the engine....?</TD></TR></TABLE>
Thought about that...but i don't think the jack will reach that far. Yeah, my front rad support was trashed on a off road excursion while at the track.
Re: Jack points...please help! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Mine is messed up too so i use the transmission as a point to lift it. Works great and doesnt mess it up at all and you could get it high enough to put jacks on the side then let go. Hope that helps.</TD></TR></TABLE>
Jacking the car up from the tranny?!?! Are you sure?!?! Man, that sounds scary...
RACEPAK
37
05-05-2005 03:19 PM
when i jack my car w/factory jack i cantr slide my jackstands on the same spot so how do you lift th
CRXstress
06-25-2004 06:09 AM
