eg rear upper wing??
Guest
Posts: n/a
ok i want to get that wing that goes on the back roof to replace that little one i got. i was searchin ebay and i found 2 type and i need to now if they are the same thing looks wise or are they 2 different style. they are below tell me what u think thanx!!!
the one below is called a duckbill wing
the one below is the jdm SIR wing
which one is better looking or are they both the same looking?
Re: eg rear upper wing?? (hatchboy93)
They are different.
The first one called the "duckbill" wing was originally designed by Spoon as a carbon fiber piece without a light. Since then, there have been many knock offs made out of fiberglass, and with LED lights incorporated.
The other one you mentioned is a JDM SiR piece. It's "similar" to the standard issue "wing" (if you can even call it that) that comes on USDM Civic hatches, but with a little bit of a difference. It sticks out a little further than the USDM standard issue, and includes a thin LED third brake light. With this JDM piece, it does not angle up like the "duckbill" but stays 180 degrees flat/horizontal.
If I find a good picture of the JDM SiR wing, I'll reply again, so that you can compare.
Hope this helps.
Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchboy93 »</TD></TR><TR><TD CLASS="quote">thanx thats what i was looking for i really want to see what the SIR wing looks like on the car it self. inyour honest opinion though what looks better the SIR or the duckbill?</TD></TR></TABLE>
SiR...
Spoon...
SiR...
Spoon...
Location: Toronto, Canada currently residing in ATL, GA, USA
I like the SIR wing (Esp the LED light) definently clean. I like the Duckbill as well.
DIY_Racing
10-16-2003 07:25 AM
