everything is fixed... BEFORE and AFTER.
this happened a few days ago
then I riveted and JB welded a piece of strong sheetmetal
trans before.
trans after a bit of hammering to contor the metal to shape, then JB weld then I pop rivet it on.
exhaust before
exhaust after, took my B16 header and cut off the piece I needed, then cut the bent part out and welded the good b16 pieces in, then JB welded the whole dam thing to seal any small leaks the welds didnt cover.
I hope that JB weld **** holds, I've romped on the car the same night I put it on and so far so good. A little ghetto looking but no big deal, nobady really gives a rats *** anyway especially me.
alo double check your flywheel is thjis ever happens. I bent mine so bad that the FW teeth were hitting the stater teeth and making a chirping sound, I replaced mine with a Fidanza unit and it works great.
Modified by fastwanabe at 4:51 AM 4/18/2003
Modified by fastwanabe at 2:47 AM 3/8/2004
trans before.
exhaust before
Re: everything is fixed... BEFORE and AFTER. (Si.Hatch.92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si.Hatch.92 »</TD></TR><TR><TD CLASS="quote">nice
wtf happened though?</TD></TR></TABLE>
I hit what I think was a raised manhole @ about 50-60mph, I really couldnt tell since it was 12-1am. All I know was I felt the entire car lift then down HARD.
Re: everything is fixed... BEFORE and AFTER. (fastwanabe)
Nice, i see you took my suggestion and used some JB Weld? I had suggested that in the first post you made when this incident happened....i guess you took my advice Told ya that **** works great!
Re: everything is fixed... BEFORE and AFTER. (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">Nice, i see you took my suggestion and used some JB Weld? I had suggested that in the first post you made when this incident happened....i guess you took my advice Told ya that **** works great!</TD></TR></TABLE>
sure does... thanks for the advice, you saved me from buying a tranny, gracias muchacho.
daaaammmnn thats some serious surgery there , looks like someone took a frikken chainsaw to the tranny,
good job
good job
Re: everything is fixed... BEFORE and AFTER. (lsvinny)
dude, can that **** withstand heat? i wanna get my cat into my exhaust (mmmmeeeeeeeoooowwww!!!! ) and need a welder but no-one has one, will that one work?
Re: everything is fixed... BEFORE and AFTER. (97civhatch)
it is an artificial weld that comes in a tube. It is strong.
i just relaized that was the worst explanation ever.
too many
too many
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">it wont hold up to vibrations.</TD></TR></TABLE>
do you know that for a fact?
Re: everything is fixed... BEFORE and AFTER. (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">why did you jb weld the header?
was it cracked?</TD></TR></TABLE>
not cracked but crushed, the guy that welded it left small holes around a few welds, I used JB weld to seal ANY leaks around the weld.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvinny »</TD></TR><TR><TD CLASS="quote">ye it will crack and then when you want to fix it right it will be a bitch to get all that stuff off.
Yep, it will crack over time. And I hope the weather was right because if the weather is to warm or to cold then it cracks of sooner and won't hold. Anyways they have this stuff, I forgot the name. Basically its space age glue and will hold anything. You could rip an alternator belt and use this glue. If you tryed ripping the belt after the glue, you won't be able to. Thats how strong the stuff is. Anyways I think you should of used that on your tranny or atleast got it welded.
