How Do I remove my Taillights?
I need to take those suckers outa there cause im putting 99-00 Si style ones in. That orange in the 98 and lower ( I have 98' ) gives me fits. So how do i take them out? SOme info on how to wire these bad boys back up would be a huge help too. Thank you
Re: How Do I remove my Taillights? (Si Arn)
There are about (8) 10mm nuts on the back side of the taillight assembly (each side). On the outside pieces, you'll need to pull the trunk carpet back. On the inside pieces, you'll need to push the taillight out possibly as the gasket tends to stick. They should plug back in like your 98's too. HTH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Arn »</TD></TR><TR><TD CLASS="quote">any more info?</TD></TR></TABLE>
Are you dumb? If you take the bolts off they
will pull out. Dont forget to disconect the wires.
that pretty much it... just look at where the screws and bolts are located. Its straight foward just swapping the tailight housing. Just make sure to change the outer turn signal bulbs to amber ones if thats a problem in your area (fix-it ticket).
