Question for those that put a OBD2 SOHC engine into a EG civic?
What IACV did you use? All OBD2 SOCH engine uses a 3 wire IACV while the OBD1 uses a 2 wire IACV. How did you guys manage to get around this? What ECU are you guys running? Thanks.
EDIT: I will be running everything OBD1 (ECU, harness). Only thing that will be OBD2 is the engine itself.
Modified by eg-six at 10:21 AM 4/17/2003
Re: Question for those that put a OBD2 SOHC engine into a EG civic? (eg-six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg-six »</TD></TR><TR><TD CLASS="quote">But i will be using a OBD1 ECU.....how will running more wires help? </TD></TR></TABLE>
See u didn't tell me that. Looking into it.
Re: Question for those that put a OBD2 SOHC engine into a EG civic? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
See u didn't tell me that. Looking into it.</TD></TR></TABLE>
Sorry.....my bad! Thanks for looking....pretty stumped about this one. Would like to solve this before taking the motor out.
I agree.....it's always nice to knwo what your getting into before you get into it.
Re: Question for those that put a OBD2 SOHC engine into a EG civic? (purek9hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid »</TD></TR><TR><TD CLASS="quote">So I take it your going to run an OBDI wiring harness??</TD></TR></TABLE>
Yes, OBD1 engine harness and ECU.
Re: Question for those that put a OBD2 SOHC engine into a EG civic? (tonesdef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonesdef »</TD></TR><TR><TD CLASS="quote">why don't you just stick with a obd1 engine. Why make things harder for your self. </TD></TR></TABLE>
Please, if you have nothing to say, keep them to yourself. If you look at my sig, you will know why i am doing this!
i have a 95 civic. i threw in a 96 civic dx (d16y7) engine in b/c my d15 crapped out. anywho. i used MY dx harness (obd1) and everything plugged in, only thing was that i used my old intake manifold. the Y7 has that weird looking one, so i used my "ex/si" looking one.... just a thought... if u have a Y8... all i can say is... uhh make something happen man. sorry.... hope i was of some help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">OBD2 auto IACVs use 3 wires
OBD2 Manual IAVCs use 2 wires.</TD></TR></TABLE>
Which wire is the extra wire for Auto?
Which wire is the extra wire for Auto? </TD></TR></TABLE>
Still researching that. Going to look at my own ECU wiring during lunch.
Will be able to answer in about an hour/hour and a half.
Will be able to answer in about an hour/hour and a half.</TD></TR></TABLE>
Thanks man! Try to get me the colour of wire if you can. Here, have a on me! Thanks again.
Okay. 3 wire IACVs have a Orange, Yellow/Black and Black/Blue.
2 wires have a Black/Blue and Yellow/Black.
On Manual OBDII ECU's the Black/Blue goes to A12 and the Yellow/Black goes to the main relay.
On Auto OBDII ECU's the Orange goes to A13, the Black/Blue goes to A14, and the Yellow/Black goes to the main relay.
The only difference is that Auto IACVs have a positive and a negative vaccum while Manuals only have positive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">Okay. 3 wire IACVs have a Orange, Yellow/Black and Black/Blue.
The only difference is that Auto IACVs have a positive and a negative vaccum while Manuals only have positive.</TD></TR></TABLE>
Thanks for the info man. But the problem still exist.....i only have one pin out on the OBD1 ECU (A9, IACV) where as a OBD2b ECU has a (B23) IACV, and a (B6) IACV P. I don't think you can run a OBD2 IACV via a OBD1 ECU.
Modified by eg-six at 2:06 PM 4/17/2003
Re: Question for those that put a OBD2 SOHC engine into a EG civic? (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">i have a 95 civic. i threw in a 96 civic dx (d16y7) engine in b/c my d15 crapped out. anywho. i used MY dx harness (obd1) and everything plugged in, only thing was that i used my old intake manifold. the Y7 has that weird looking one, so i used my "ex/si" looking one.... just a thought... if u have a Y8... all i can say is... uhh make something happen man. sorry.... hope i was of some help.</TD></TR></TABLE>
Thanks for the info....alot of research has all pointed that i will need a OBD1 intake manifold in order for this thing to work....i guess the hunt is on. Thanks guys for all the help! Cheers!
eg i was just wondering, is this a y8 obd2 engine you swapped in? Because if it is and its 3 wire, you have an engine from an auto as spade said. But all y7's have 3 wire also. So maybe a manual IM from a y8 would work for him?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">Just a Manual IACV and not an Automatic.
That's the difference.</TD></TR></TABLE>
Sorry....but i don't get what you are trying to say. But if you look at the ECU, there is actually a pin for IACV P which i don't have on the OBD1 ECU.
Re: (brooksto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brooksto »</TD></TR><TR><TD CLASS="quote">eg i was just wondering, is this a y8 obd2 engine you swapped in? Because if it is and its 3 wire, you have an engine from an auto as spade said. But all y7's have 3 wire also. So maybe a manual IM from a y8 would work for him?</TD></TR></TABLE>
I am doing a manual Y7 into a EG chassis hence i have 3 wires for the IACV where as the EG only has 2.
be18see1
04-01-2007 08:58 AM
