whats the strongest japanese single cam motor....
Re: whats the strongest japanese single cam motor.... (ek four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek four »</TD></TR><TR><TD CLASS="quote">i wanted to know which is the strongest japanese single cam motor available. this would be going into my daily driver - 93 cx.</TD></TR></TABLE>
the motor that comes with it
D16Y8. (Which is identical to the USDM D16Y8)
is this the one that comes in the US 92-95 si's?</TD></TR></TABLE>
Nope. That would be the D16Z6.
The D16Y8 is the 96-00 EX's
Re: whats the strongest japanese single cam motor.... (Spade)
What about the 1.7L (1668cc) motors in the new 2001+ civic? I don't know if it is d series or not but it is a 16-Valve SOHC VTEC motor w/ 127hp @ 6300, 114lb.-ft. @ 4800, and 9.9:1 compression ratio (according to honda.com). The D16Y8 has 1.6L (1590cc) 16-Valve SOHC VTEC motor w/ 127hp @ 6600, 107 @ 5500 and 9.6:1 compression ratio (according to autos.msn.com). The 2001+ has slightly better torque and displacement. Am I missing something as to why the D16Y8 is better? Please elaborate why if it is better than the 2001+.
i always thought that the 92-95 si's were stronger then the 96-00 ex's.</TD></TR></TABLE>
according to autos.msn.com, 92-95 Si has 1590cc, 125hp, and 106lb.-ft., 9.2 Compression Ratio. So comparing the two the 96-00 ex is rated 2hp & 1lb.-ft. higher, and a 0.4 difference in compression ratio. Oh, and its OBDI
New User
the d16y8 (96-00) has 2 horsepower over the Z6 (92-95).
The d16y8 has a better combustion chamber design, and more compression. However, it is belived that the Z6 has better a better flowing head.
I did a lot of research before i did my set up in my 92 Si, and i went with a low-mileaged D16y7 bottom end (96-00 Lx and DX, 250 bucks) and the d16z6 head (came w/ the car, re-built it, cleaned out all the carbon and replaced the valve seals). The result? 15.6 @88mph on street tires and a full interior. Nothing to brag about or anything, but its nice and punchy for daily driving
Modified by euclidEH3 at 3:09 AM 4/19/2003
Re: whats the strongest japanese single cam motor.... (96BlackHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BlackHB »</TD></TR><TR><TD CLASS="quote">What about the 1.7L (1668cc) motors in the new 2001+ civic? I don't know if it is d series or not but it is a 16-Valve SOHC VTEC motor w/ 127hp @ 6300, 114lb.-ft. @ 4800, and 9.9:1 compression ratio (according to honda.com). The D16Y8 has 1.6L (1590cc) 16-Valve SOHC VTEC motor w/ 127hp @ 6600, 107 @ 5500 and 9.6:1 compression ratio (according to autos.msn.com). The 2001+ has slightly better torque and displacement. Am I missing something as to why the D16Y8 is better? Please elaborate why if it is better than the 2001+.</TD></TR></TABLE>
That is a better engine yes, but it's harder to swap than a H22. The returnless fuel is tricky as hell, the smog equipment is a major PITA and the intake manfiolds are composite plastic.
It's not an engine you want.
Thanks for the info ...don't really know anything about the 2001+ engine or it was such a PITA to swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BlackHB »</TD></TR><TR><TD CLASS="quote">Thanks for the info ...don't really know anything about the 2001+ engine or it was such a PITA to swap </TD></TR></TABLE>
Oh yeah, one more thing. You can convert a D16Y8 to OBDI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
D16Y8. (Which is identical to the USDM D16Y8)</TD></TR></TABLE>
aren't the z6 and y8 rated at the same hp to the crank?
Re: whats the strongest japanese single cam motor.... (Westsideboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westsideboy »</TD></TR><TR><TD CLASS="quote">D16Y8...too bad it's OBDII </TD></TR></TABLE>
Mine used to be, but now that I have the Hondata Stage 2B I am OBDI.
Re: (Civic4doors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4doors »</TD></TR><TR><TD CLASS="quote">There is a D15B that is a 130 HP,
basicly the D16Z6 head on a D15 block.
But strait from Japan</TD></TR></TABLE>
B16 of the D series.....torqueless wonder.
Re: whats the strongest japanese single cam motor.... (Nine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine »</TD></TR><TR><TD CLASS="quote">Would it be possible to swap a d16z6 head on a d17 block?</TD></TR></TABLE>
ttt
ttt
Location: South Bay, Torrance/Carson, CA, United States
go with the d15b. 130 hp and its relatively inexpensive. i have one in my car right now.
Re: whats the strongest japanese single cam motor.... (iluvjasmine)
F22....sohc...150hp, 150tq.... as hard to swap as an H22.... woo hoo !!
I have a straight d16z6, 125hp stock... the Y8 has 127 stock, but the head doesnt' flow as well up top...
I ran a 15.3 in my hatch w/ just I/E on the Z6... it's already OBDI and has pretty good tq for a sohc...
X2
X2
Bisimoto
13
01-22-2007 06:50 AM
clubEmoKiller9
07-16-2006 05:02 PM
