sway bar on 6 gen hatch question.
i have a 6gen hatch cx that handles very nicely with the tanabe suspension that i have on it. however it still understeers and i want it to be a lil bit more neutral. so i'm thinkin bout puttin on a sway bar in the rear only. and i heard that the cx model doesn't come with sway bars on front or rear. and that the respective points where a sway bar can attach also aren't there.
so my question is which sway bar should i use. I perfer an OEM one. cause I think the aftermarket ones are a lil too stiff for my set up. and does it bolt up or do i have to drill some holes?
thanks in advance.
thanks in advance.
Re: sway bar on 6 gen hatch question. (racin-type)
if you choose to install only a rear sway bar I would not go any larger than the CIVIC SI(99-00) factory 13mm rear sway bar.. but if you must have a front and a rear.. I recommend the Civic si/CTR 24mm front in which you will need the LCA'S and shock forks for the front(someone correct me on the front swaybar size I forget)... ITR 22mm rear setup in which you will use a beaks reinforcement kit plus civic si endlinks
http://www.beaksproducts.com/srk-ek.html good luck
Re: sway bar on 6 gen hatch question. (IM ALL BOB)
thanks for the info i didn't kno the SI had sway bars that small i think i'm goin to go with those are there any problems or specific parts off of the SI suspension i need for the swap?
thanks
thanks
EJ1 wilcox
Suspension & Brakes
23
03-14-2006 12:49 PM
bw54867
10-14-2002 06:51 PM
