FAQ: Need ECU Pinouts? Then look inside.
Old 04-17-2003, 08:38 AM
Spade's Avatar
Default Need ECU Pinouts? Then look inside.
I've been looking at this for a while. Too many people need to know what goes where and the information is hard to dig up.
-If you have a generation that is not listed here please add it to the post and I will copy and add it. (Keep them all up top)
More stuff: http://pgmfi.crx-forum.org/res....html
Courtesy of tonyXcom:Complete ECU and Engine harness Helms scans for the 00 Intergra and 96-98 Civic
** means I don't have that particular one and would like it. Feel free to IM me about it.
ECU plug comparison Courtesy of Katman
OBD2 CIVIC-INTEGRA (96-98)
A1-INJ4
A2-INJ3
A3-INJ2
A4-INJ1
A5-**
A6-**
A7-**
A8-VTEC SOLENIOD
A9-LG1
A10-PG1
A11-IGP1
A12-IACV
A13-IACVN
A14-IACVP
A15-PCS
A16-FLR
A17-ACC
A18-MIL
A19-ALTC
A20-ICM
A21-empty
A22-LG2
A23-PG2
A24-IGP2
A25-VREF
A26-IAB SOLENOID
A27-FANC
A28-2WBS
A29-VSV
A30-SLU
C1-CKFP
C2-CKPP
C3-TDCP
C4-CYPP
C5-ACS
C6-STS
C7-SCS
C8-**
C9-TMA
C10-VBU
C11-CKFM
C12-CKPM
C13-TDCM
C14-CYPM
C15-VTEC PRESSURE SWITCH
C16-PSPSW
C17-ALTF
C18-VSS
C19-empty
C20-empty
C21-empty
C22-empty
C23-IP+
C24-**
C25-VS+
C26-empty
C27-empty
C28-empty
C29-**
C30-TMB
D1-TPS
D2-ECT
D3-MAP
D4-**
D5-BKSW
D6-KNOCK SENSOR
D7-**
D8-IAT
D9-**
D10-VCC2
D11-SG2
D12-SG1
D13-**
D14-**
D15-**
D16-EL
PR3
A01-INJ1 fuel injector control # 1
A02-PG1 Ground
A03-INJ2 fuel injector control # 2
A04-PG2 Ground
A05-INJ3 fuel injector control # 3
A06-**
A07-INJ4 fuel injector control # 4
A08-VTS VTEC solenoid
A09-**
A10-**
A11-IACV from electronic air control valv
A12-FLR1 fuel pump control
A13-IGP1 power Input
A14-FLR2 fuel pump control
A15-IGP2 power Input
A16-**
A17-**
A18-**
B01-VBP Battery Backup
B02-**
B03-ACC a/c compressor clutch relay cont
B04-FANC
B05-VTM VTEC pressure switch
B06-MIL check engine warning light
B07-**
B08-ACS a/c on input
B09-**
B10-CYP P crank sensor (1)
B11-**
B12-CYP M crank sensor (2)
B13-**
B14-ALT alternator output signal
B15-**
B16-VSS VSS
B17-**
B18-**
B19-KS Knock sensor
B20-SCS ignition timing adjusting connec
C01-CKP P CYL sensor (1)
C02-CKP M CYL sensor (2)
C03-TDC P TDC sensor (1)
C04-TDC M TDC sensor (2)
C05-IAT intake air temperature sensor
C06-ECT coolant temperature sensor
C07-TPS throttle angle sensor
C08-O2S Dual O2 Sensor (JDM)
C09-PA atomosphere pressure sensor inpu
C10-BKSW brake light switch
C11-MIL ground
C12-SG2 TPS GND
C13-VCC1 TPS 5V
C14-SG1 MAP GND
C15-VCC2 MAP 5V
C16-O2S oxygen sensor
OBD1
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A4-VTS VTEC solenoid
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22- *per Sander* Ignitor
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
D6-VTM VTEC pressure switch
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
Modified by Spade at 1:17 PM 11/12/2003
Old 04-17-2003, 08:44 AM
piscorpio's Avatar
Default Re: Need ECU Pinouts? Then look inside. (Spade)
Nice!
I assume you no longer need my help? I had been trying to round up all the pinouts, but I just didn't have time to sit down with the manual.
Old 04-17-2003, 08:50 AM
tonyxcom's Avatar
I have some stuff at
http://www.tleone.com/hondatech
You will find some complete ECU and Engine harness Helms scans for the
EDIT: 6/24/2003 : Added 98 Integra ECU Pinouts
Modified by tonyXcom at 5:10 PM 6/24/2003
Old 04-17-2003, 02:13 PM
Spade's Avatar
Default Re: Need ECU Pinouts? Then look inside. (tonyXcom)
Added pics and links.
Top.
Old 05-09-2003, 01:52 PM
silverEH2's Avatar
bump for good post.....save to notepad
Old 05-09-2003, 02:39 PM
duRritztiNy's Avatar
Old 05-09-2003, 03:35 PM
Fuster_Cluck's Avatar
Default Re: Need ECU Pinouts? Then look inside. (SouthSideRacing)
Good info!
Those diagrams helped me with my Eg/GSR swap
Old 05-10-2003, 01:35 AM
EKFerioHawaii's Avatar
Default Re: Need ECU Pinouts? Then look inside. (JV)
Its days like these that I've been waiting for as an HT member....
Thanks alot guys!! *crys*
Old 05-10-2003, 02:06 PM
96BlackHB's Avatar
Very useful information! Thanks, Spade, tonyXcom, and JV! Could someone else confirmed that the first ob1 pic (in Spade's first post) is labeled wrong for a4 and d6?
Old 05-10-2003, 02:47 PM
made in JAPAN's Avatar
Default Re: Need ECU Pinouts? Then look inside. (96BlackHB)
i just noticed this was labeled wrong also and was about to warn people about it but somebody already did. just wish i had descovered it sooner because i have been pulling my hair out the last 2 weeks trying ti figure out why my vtec wasnt working
Old 05-22-2003, 09:45 AM
infamousALLMTR's Avatar
where is the location for obdo for vtec?
thanks you
mike
Old 05-23-2003, 01:21 AM
91civicDXdude's Avatar
^^ i'd like to know this as well.
Old 05-23-2003, 02:00 AM
EddieHatchBlack's Avatar
Default Re: (91civicDXdude)
So the first diagram is how to hook up B-series engines in a 96-98 civic? (using the simplest...Civic EX harness)??
Old 05-28-2003, 11:21 AM
cxSHOE's Avatar
did we every get an update on where it is suppose to be located???? thanks for any help.......
Old 05-28-2003, 12:33 PM
Spade's Avatar
Default Re: Need ECU Pinouts? Then look inside. (88hf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88hf &raquo;</TD></TR><TR><TD CLASS="quote"> Could someone else confirmed that the first ob1 pic (in Spade's first post) is labeled wrong for a4 and d6?
did we every get an update on where it is suppose to be located???? thanks for any help.......</TD></TR></TABLE>
FIXED.
Old 06-01-2003, 08:11 AM
noPistons's Avatar
thanx u spade!!!!!!!!!
u are a god in my book(bowing dn too the ecu god)
Old 06-01-2003, 08:32 AM
noPistons's Avatar
hey spade do u have the diffrent colors of the wires threw out the years?? i need the color code for a 97cx and a automatic 00ls if you or anyone can pull these up thanx
Old 06-02-2003, 11:09 AM
noPistons's Avatar
Old 06-02-2003, 11:26 AM
tonyxcom's Avatar
Default Re: (noPistons)
buy a helms.
Old 06-16-2003, 08:12 AM
skunk2unerz's Avatar
Default Re: (88hf)
my sticky note.
Old 11-06-2003, 09:56 PM
Snail Tuning's Avatar
i need the 99-01 civic p2p i think is the ecu.
anyone help me out?
thanks
Old 11-06-2003, 09:57 PM
aw1234dude's Avatar
Default Re: Need ECU Pinouts? Then look inside. (bmcc72)
This?
Old 11-06-2003, 10:06 PM
vladd's Avatar
thanks a lot!!! is there any way you could get the 5th gen cx pinouts, too, please?!?
Old 11-06-2003, 10:08 PM
Default Re: Need ECU Pinouts? Then look inside. (aw1234dude)
would u happen to have the list of what each pin is? thanks for the picture. but i could really use the list.
Old 11-06-2003, 10:18 PM
aw1234dude's Avatar
Heres a website that i found useful while doing a swap.
http://www.hondaswap.com/swap/viewer.php?id=58
Quick Reply: FAQ: Need ECU Pinouts? Then look inside.
