oil sending unit.92-95 same as 96-00?
are the oil sending units(found on the back of the block) the same for 92-00 civics?or are they different between models(ex,si,dx,cx,etc) or years(92-95,96-00)?
Re: oil sending unit.92-95 same as 96-00? (PA MATT)
Same for all D/B/H/F series motors. Uses the same 1/8" NPT thread to screw into the back of the block. Most use the same bullet-plug setup, where as some use a ringlet connector with a screw, but both do the samething.
Re: oil sending unit.92-95 same as 96-00? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">Same for all D/B/H/F series motors. Uses the same 1/8" NPT thread to screw into the back of the block. Most use the same bullet-plug setup, where as some use a ringlet connector with a screw, but both do the samething.</TD></TR></TABLE>
1/8" BSPT
1/8" BSPT
Re: oil sending unit.92-95 same as 96-00? (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">well if there is two different types...would the wiring have to be switched???</TD></TR></TABLE>
need to know this asap...somebody help please
