02 Sensor Problem...
Old Jul 19, 2004 | 12:49 AM
r0guish's Avatar
Default 02 Sensor Problem...
Hey Guys,
I need some help. I have a 95 Civic Lx with an autobox (or should I say had); anyway I did a tranny conversion and decided to swap in a JDM B18C. The car runs great, especially with all its mods installed: hasprt mounts, greddy evo II exhaust, DC header, aem short intake, high-flo cat (still need to install aem cam gears, jg edelbrock manifold, edelbrock 65mm throttle, toda timing belt, ground wires, and some guages I have lying around). And the problem is that I'm throwing a 1 engine code (the 02 sensor). I installed the sensor, but still throwing the code. I noticed that the Civic had the 02 located at the middle of header, while the stock gsr had it located at the very end of the header. Could the location of the sensor be the problem? Or is it the wiring? I have the Hasport subharness installed and everything runs great (gotta luv vtec!), but the engine light is annoying. I have about a year before my next smog check-up, but I'd like to have the car bar'ed before then, so if anyone has any suggestions, it'll be appreciated.
Thanks,
B
-anyone have the civic lx ecu pinout chart available?
Old Jul 19, 2004 | 04:28 AM
TurboBumblBee's Avatar
Default Re: 02 Sensor Problem... (r0guish)
are you using an obd2 ecu?? and if so do you have both o2 sensors installed?? if not thats your problem..
Old Jul 19, 2004 | 07:14 AM
r0guish's Avatar
Default Re: 02 Sensor Problem... (TurboBumblBee)
Well the place that I got the B18C said it was a 95 (obd1), so I'm not sure. Is there anyway I could find out whether it is or not? I'm sure if it was an obd2 it wouldn't be much of a problem cuz I have another 02 sensor lying around (i got another one thinking it was just a bad sensor) plus my cat has a place for the sensor (behind it), I just got a nut in it.
Thanks for the help
B
Old Aug 2, 2004 | 10:39 AM
r0guish's Avatar
Anyone else have any advice? I was also thinking that it could be faulty wiring, or a mis-matched wiring from the harness to the ECU, perhaps...
B
Old Aug 2, 2004 | 05:51 PM
DALE-EK4's Avatar
Do a continuity test on all four of the wires from the 02 sensor to the correct pins on the ecu with the ecu unplugged. I had this same issue for a long time until i did this and found out i was missing the white wire. Hope that helps
Clarkscivic802
Honda Civic (2001 - 2005)
Sep 3, 2016 04:04 AM
garnet
Jun 28, 2014 05:20 PM
cribby94
Jan 26, 2013 08:26 AM
jaredvabeach
Jan 20, 2009 05:59 PM
wavewuver
Jan 6, 2005 04:48 AM
