simple question i need help with...
yo, last night my gas peddle got stuck under my floor mat and my motor was tapping the rev limiter for a good 15-30 seconds. mods are just a test pipe on my lil' ol' d16z6. whats the worse case scenario? would my motor blow? i have quite a bit of miles on my motor already so im just wondering...
Re: simple question i need help with... (hondachick05)
if its not knocking or tapping now, and didnt detonate or anything when this happened, then dont worry about it. might need a valve adjustment now, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachick05 »</TD></TR><TR><TD CLASS="quote">ur not having a lot of luck are you? first ur lights and now ur pedal gets stuck. How many miles does it have?</TD></TR></TABLE>
hahaha, yea, i dont exactly have good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew96EJ »</TD></TR><TR><TD CLASS="quote">if its not knocking or tapping now, and didnt detonate or anything when this happened, then dont worry about it. might need a valve adjustment now, though.</TD></TR></TABLE>
i see, so this can cause your valves to tap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashN2u »</TD></TR><TR><TD CLASS="quote">It didn't cut the fuel?</TD></TR></TABLE>
nope, it hit the limiter a couple 5-10 times, ahah
Re: (EJcoupe)
15-30 is quite a long time but thats why the rev limiter is there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe »</TD></TR><TR><TD CLASS="quote">hmm okay, so out of curiosity, what if i was a dumb **** and did this all the time, what would be the results</TD></TR></TABLE>
then you shouldnt be behind the wheel.
ahah, good enough. thanks for the help
btw: 92-95's should come w/ that accessory that comes stock on accords that keep the floor mat in place. i guess this is the reason to buy it now
Blazin Si
06-18-2004 01:02 PM
