Check engine light, doesn't light up when checking code. WHY!!
Old Jul 18, 2004 | 09:25 PM
allmotorEG-SI's Avatar
Default Check engine light, doesn't light up when checking code. WHY!!
I belive I am checking it correctly. Under the passengeer kick panel, 3 plugs. big grey one, brown one with 2 wires. Both are pluged into something. Then a blue one with 3 wires, this isn't plugged into anything. It has a black wire w/red strip a blue and a white wire. I connected the black and blue ones, the 2 outside wires, and when I turned the iginition to the on position the CEL doesn't turn on but stays on all the time while driving(with the wires not jumped of course)
WHAT DOES THIS MEAN!?
Old Jul 18, 2004 | 10:48 PM
dantastic's Avatar
it means you're jumping the wrong wires. there is a 2pin plug that's not plugged into anything. you need to connect those 2 pins, then turn the car to the on position to check the codes
Old Jul 19, 2004 | 12:25 AM
JDMlyfestyle's Avatar
check out my ecu code thread in my signature. seems to help alot of people. theres pics and videos and a write up on how to check your codesq
Old Jul 19, 2004 | 06:34 AM
damn that grey plug. I can't find that little SOB. It must be tucked up in there good or something.
Old Jul 19, 2004 | 06:38 AM
CRITTERMATT's Avatar
Default Re: (allmotorEG-SI)
there is a green rubber holder tucked up in there. pull the rubber holder down and then pull the plug out of it. the green rubber holds the plug up in the car.
Old Jul 20, 2004 | 09:31 PM
well, i looked in there deep and couldn't find the grey plug. just the blue one with white wire, blue wire and black wire with red strip.
Old Jul 20, 2004 | 09:45 PM
wizzards581's Avatar
mine is a blue plug. small plug 2 wire.
Old Jul 20, 2004 | 09:51 PM
small plug 2 wire... the only plug with 2 wires down there is brown with a blue and white wire and its plugged into a harness and being used.
TegraD
Aug 16, 2008 07:05 PM
Civicta
Jul 17, 2004 09:06 AM
93EH6
Jan 30, 2003 09:11 PM
Simple
Nov 22, 2002 10:49 AM
