ITR LCA's into 92+ JDM EG ?
Posting for a buddy of mine.
He has a JDM EG hatch which came stock with a sway bar and LCAs w/ mounting holes.
He has decided to switch to CTR shocks, so he needed to change the LCAs to line up. I would assume he needs ITR or CTR LCAs to complete this....
Is the ITR or CTR LCA a direct bolt on into an EG (always thought they were) ? Or is something else required ?
Thanks
X2
Thanks
X2
Re: ITR LCA's into 92+ JDM EG ? (X2BOARD)
ITR LCA's will not fit onto CTR dampers since they bolt up the same way the USDM 96-00 Civics do. I do recall Emerika here had modified GSR LCA's to fit Coilovers from an EK.
Re: ITR LCA's into 92+ JDM EG ? (Mr_Tadashi)
Sooo.... CTR LCA's are not the same as ITR LCA's
However the ITR LCAs fit an EG... is this with proper camber or did you need some major adjustment ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD »</TD></TR><TR><TD CLASS="quote">Sooo.... CTR LCA's are not the same as ITR LCA's
However the ITR LCAs fit an EG... is this with proper camber or did you need some major adjustment ?</TD></TR></TABLE>
When i dropped mine in camber is still fine. as long as the toe adjuster isnt touched i dont see why it would mess up
le0ftw
04-12-2007 05:39 PM
skribblah
07-26-2003 11:14 AM
