Sway Bar install problems?!?!?
i recently bought a progress 22mm rear sway bar from someone on here and it totally doesn't look like it, from my first attempt at installing it, would fit. the person i bought it from told me that it came off of his 97 ek hatchback and i have a 99 ek coupe, shouldn't it be the same? the d brackets don't fit into the orginal oem holes, so it comes with brackets so that they fit. but the brackets drop the point where your supposed to bolt the d brackets in and now i cant really fit it because i have a tie bar and it sits right next to the brackets. but on the other hand it totally seems to be to wide for my car totally though. the endlinks like arn't even close to where they are supposed to bolt in to the lca's. mabye im installing it wrong or it's the wrong sway bar for my car, i dunno. but if someone could help with some pictures or a diagram of kind, that would help out a lot too!
Re: Sway Bar install problems?!?!? (FF:core)
you can't have a tie bar with the progress sway bar
https://honda-tech.com/zerothread?id=917016
people said that sway bar is dangerous because it might rip the subframe off
will be sending you the payment for the apexi WS coilovers soon
