S/V-AFC NOOB QUESTION
Hello
i am hella shamed to ask this.
but what are the diffrences between S-afc and V-AFC?
is v-afc for vtec engines ?
and s-afc for sohc engines?
best regards moshik galimidi
Electrician
V-AFC is to tune your VTEC engagement point. It is also used to tune your air and fuel ratio. Could be used on SOHC and DOHC VTEC motors and also depends on how built your motor is (cylinder head and block).
S-AFC is to tune your air and fuel ratio depending on how built your motor is (cylinder head and block).
Both DEFINITELY need to be tuned at a professional place with a dyno.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">V-AFC is to tune your VTEC engagement point. It is also used to tune your air and fuel ratio. Could be used on SOHC and DOHC VTEC motors and also depends on how built your motor is (cylinder head and block).
Both DEFINITELY need to be tuned at a professional place with a dyno.</TD></TR></TABLE>
Expanded, if you have a ton of internal mods, high compression, etc. Get a standalone like Hondata, AEM, etc.
The SAFC is primarily for non VTEC Honda motors, since it doesn't require the VTEC function. They also tend to be cheaper.
Re: (REVHARD_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF »</TD></TR><TR><TD CLASS="quote">
The SAFC is primarily for non VTEC Honda motors, since it doesn't require the VTEC function. They also tend to be cheaper.</TD></TR></TABLE>
SAFC is for non VTEC motors period, not just honda motors...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">can i use vafc and cancel the vtec mod?
and use it just as a air/fuel "controler"?</TD></TR></TABLE>
Does your engine have vtec? You don't HAVE to change your vtec settings, but you should NOT use a VAFC on a non-vtec engine. Use a SAFC for non-vtec engines.
To summarize, VTEC engine = SAFC or VAFC
non-VTEC engine = SAFC ONLY...
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">[QUOTE=ShakesTheKlown]
Does your engine have vtec? QUOTE]
my engine is non vtec.
can i use the vafc without the vtec function? </TD></TR></TABLE>
I'm not sure...if you have a VAFC but don't have VTEC, just throw the VAFC up on eBay or something and pick up a SAFC...you will probably make a few extra bucks in the process
Re: (zanthrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax »</TD></TR><TR><TD CLASS="quote">Does that mean a V-AFC won't work on a non-vtec engine?
You wouldn't be able to hook up all the wires for the VAFC, since there is no VTEC oil pressure sensor wire, and no VTEC solenoid, so as I said quite clearly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShakesTheKlown »</TD></TR><TR><TD CLASS="quote">
non-VTEC engine = SAFC ONLY...</TD></TR></TABLE>
Re: (ShakesTheKlown)
Cant the SAFC also work as a boost controller? I know one of the AFC's did that but not sure which one.
Edit: never mind i went to Apexi and the site said its the AVC - R
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Cant the SAFC also work as a boost controller? I know one of the AFC's did that but not sure which one.
Edit: never mind i went to Apexi and the site said its the AVC - R </TD></TR></TABLE>
Boost controller - no
Electronic boost gauge - YES!
What a deal huh? AFC plus a free electronic boost gauge
Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
What a deal huh? AFC plus a free electronic boost gauge </TD></TR></TABLE>
Does it actually have a boost gauge, or can you just use the MAP sensor readout as one?
TSPeed Factory
Re: (RACEPAK)
yes you can, but you'll be better off with a SAFC. also, i hear that the SAFC has more tuning capabilities then the VAFC offers.
