my civic is being weird... newbie... HELP PLEASE!!!
I have a civic 99 ex
when i idle and have the A/C on, the rpms kind of rev up and down by themselves.
it's okay for a second when i gas it
does anyone know how to fix this? do i need to add more freeon or something?
thanks
thanks
1 Post
Re: my civic is being weird... newbie... HELP PLEASE!!! (mushu315)
freon has something to do with your engine ?... odd..
just replace some of your grounds, esp the alt and any grounds on the ac system
If there's too little or too much refrigerant in the system the A/C compressor will kick on and off. Too much causes the system to overload and shut itself off and too little gives the system nothing to compress. It's somewhat normal for your idle to jump a little when your A/C kicks on and off.
How fast do the cycles occur? If it's a patterned on and off, it's probably a lack of refrigerant. Let me know.
Re: my civic is being weird... newbie... HELP PLEASE!!! (Mistamike17)
well, it'll rev from 1000 to 1500 rpm when i idle. and yes, my engine makes this...
"trying to compress something" noise when the A/C is on.
i think it might be lack of refrigerant; i don't think i had a checked since i got the car. (1999, 80,000 miles)
unless Honda will check it during the major tune up?
how do i add more refrigerant? can I do it myself?
thanks
thanks
you can do it yourself they make kits to fill ur a/c system you buy th **** at like autozone and its about $35 you connect it to the low side connector (the one with the blue cap under your hood) and there is a gauge on the hose and it tells you in the instructions what color on the gauge to stop at... i used to work at AZ and do that in the parking lot for people on my luch break its cake
Re: my civic is being weird... newbie... HELP PLEASE!!! (crxjester)
Walmart has that **** for like $20... Just check it out and make sure you get a kit with a gauge.
carispossessed
Honda Civic (2001 - 2005)
11-07-2016 04:09 PM
92civeg
06-19-2013 08:59 AM
Rooftop-Special
09-02-2010 08:08 PM
