what rear sways will bolt to factory lca's?
looking for something around 18mm for my eg- have the stock eg/dc/del sol rear lca's and 15mm del sol rear sway right now, looking to upgrade to something a hair stiffer. I really like the Mugen 18mm, not trying to drop $$$$ mad loot just for some 'JDM y0!' **** tho- something that will work well but cheap...
Anyone?
thx
Anyone?
thx
Re: what rear sways will bolt to factory lca's? (stmotorsports)
SRR unit will work although you need to buy there tie bar which is more like a mounting plate. it is 19mm it mounts to the stock lca
i think SPC or some company makes something similar to it with a 19mm sway bar not sure though there is a chance its another company with 3 letters that stand for there name and i can't remeber it right now
for the most part almost all sway bar mount to the same hole on the LCA. some mount to the shock bolt (ground control had a setup like this some other do to), and some others have a braket that clamps onto the LCA (for car that don't have the hole)
Re: what rear sways will bolt to factory lca's? (slammed_93_hatch)
you can always just opt for the ITR rear swap but it is either 21 or 22mm depending on which one you get
I would reccomend getting a breaks kit so you reduce the risk of tearing your subframe
Re: what rear sways will bolt to factory lca's? (dirtyd463)
i don't think the itr bar will mount to normal eg/dc rear lower arms will it? i thought you had to get the itr arms and all that...?
I dunno if its a good deal or not but passwordjdm.com had both jdm and usdm itr rear bars on there page for about $100 last I looked. They include everything you will need too if you allready have a bar mounted.
Maby you can get a discount because they are a HT sponsor now.
Mats_A_G
09-03-2012 03:16 PM
724chris
03-20-2011 06:21 PM
scottsopko320
07-29-2008 12:55 AM
sol2nr
10
02-17-2004 06:29 PM
