Where is the speed sensor?!?!?
My speedometer isnt working after my B16 swap into my EG. I was told it has to do with the VSS, where is it and what do i have to do to get to it.
Re: Where is the speed sensor?!?!? (jammin civic)
did you do the swap? did you fill the tranny fluid? its the sensor on top of the trans right by where younfilled the tranny fluid...its a weird looking sensor you shouldnt have to do anything to get to it..maybe remove the intake so you can get some light down there to be able to see
Re: Where is the speed sensor?!?!? (Grip)
Right on top of the transmission...
There should be three bolts but you only have to remove the one on the top right to pull it out of the transmission...
I'll see if I can find a picture...
Re: (m3dia_lab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab »</TD></TR><TR><TD CLASS="quote">how do you check this to know if its working or not, my speedo dosent work.</TD></TR></TABLE>
Re: (m3dia_lab)
if its ob2 you can buy one of those scanners at autozone i belive otherwise theres a better tool that shops use to check that, either way you plug it into your computer port and take a drive and the computer will show you if its working or not
Re: (m3dia_lab)
i hsvr the top part of the vss if ya want to try it you can see it here behind the dizzy
let it got really cheap
dun know if it will fit a b series tranny it id off a d series tranny
Re: (m3dia_lab)
Are you sure the sensor is the reason your speedo doesn't work?
I would check everything else first...all connections, cluster etc...
If I remember right, the vss is not cheap!
Re: (Slow98sedan)
check to make sure the screws are on the back of the cluster on the speedometer, the speed sensor reads off a gear in the transmission...
Re: (97ShLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">Yes if you had bigger wheels and tires it would throw it off a bit. If i'm not mistaken it is also thrown off if you change the final drive.</TD></TR></TABLE>
I almost got enough money for that motec cluster, it has these radar speed sensors. Reads off of the ground or tire.
