type r lsd in a b16 tranny
can i use a oem type r lsd in my 99-00 si tranny? i search and did not find a anwser. someone told me the 99-00 si tranny has a differnt size ring gear on the diff and you can't mix the two.
Re: type r lsd in a b16 tranny (civic dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic dx »</TD></TR><TR><TD CLASS="quote">someone told me the 99-00 si tranny has a differnt size ring gear on the diff and you can't mix the two. </TD></TR></TABLE>
they were right the ring gear is different.....it is my understanding that the Type R lsd will fit only in a Type R tranny or a GSR tranny....im not 100 percent on that though so if anyone else can help....please do
Re: type r lsd in a b16 tranny (Madspeed)
if i had the type r ring gear would it then work? they are both 4.4 fine drive so it seams like it would work.
Re: type r lsd in a b16 tranny (drifter57)
As above with an ITR ring gear the CTR/ITR lsd will work in a hydro b16a tranny. It'll need to be shimmed slightly different however. I have this mod done as well.
I've also heard a GSR ring gear will work but I can't confirm.
red civic standard
09-18-2003 08:02 AM
