rattle noise under hood?
* B A N N E D *
I have a 93 civic ex sedan and eveytime I leave in the morning to school and reverse out I here these annoying rattles under the hood? for some reason it only happens when I start the car for the first time of the day. what can I look for? is there something I should tighten? thanks
Re: rattle noise under hood? (integlsR)
snakes!!! watch out, they're poisonous...
you're going to have to be a lot more specific... where under the hood are they coming from? Does the engine shift around under load? (set parking brake and put car in gear, have someone look for movement). heavy clunk? tinny rattle? does it happen any other time. etc. etc.
Re: (SleepyCx)
A low level of "blinker fluid"? Could you explain what you're talking about. I honestly have no clue what you're talking about (if you're being serious).
Re: (SleepyCx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxjester »</TD></TR><TR><TD CLASS="quote">blinker fluid.........................haha</TD></TR></TABLE>
pep boys and autozone have it.... otherwise you have to go to the stealership
Re: (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">
pep boys and autozone have it.... otherwise you have to go to the stealership</TD></TR></TABLE> no no no no...... u got it all wrong.... the only place ive seen that has it is directly from honda... and the blinker fluid is the fluid that protects the tranny when its cold.... it drys up after about 23k miles.... just call and ask for blinker fluid #15 DOT:6
Re: rattle noise under hood? (projekt4dr)
could be several things. if its a aluminum like rattling id check the tightness of your header and anything else that bolts up to the block/head. if the sound is coming from the head, it might be the valves in need of adjusting.
could be a lot of stuff as stated above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlsR »</TD></TR><TR><TD CLASS="quote">I have a 93 civic ex sedan and eveytime I leave in the morning to school and reverse out I here these annoying rattles under the hood? for some reason it only happens when I start the car for the first time of the day. what can I look for? is there something I should tighten? thanks</TD></TR></TABLE>
It's most likely a heatsheild or exhaust component. Mine started doing that when cold recently. Freaked me out the first time because it was very loud and sounded like something internal. Now it's getting a little more loose, and you can hear the standard metal vibration noise of a heatsheild. I can't seem to track down the exact culprit yet though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekt4dr »</TD></TR><TR><TD CLASS="quote">maybe motor mount inserts ?? </TD></TR></TABLE>
Could be that. That is what happens to my del sol. It sounds more like a clunking though. Check the torque mounts (lower motor mounts) to see if they are cracked or chewed up (rubber inside the metal).
