Installed Skunk2 manifold & hondata gasket, now motor runs rough
I installed a new skunk2 manifold & Hondata gasket. Now my motor runs rough.
I set everything like it was @ factory, Injectors with spacers etc. Is there something special that I needed to do?
B20/B16a, Rc 370cc's, Str 68mm TB.
Re: (FWejCOUPE)
I put a block off plate on the bottom of the IAC valve so that no coolant will flow through. The car is low on coolant though.
1 Post
Re: (BahamaEKcrvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BahamaEKcrvtec »</TD></TR><TR><TD CLASS="quote">I put a block off plate on the bottom of the IAC valve so that no coolant will flow through. The car is low on coolant though. </TD></TR></TABLE>
bleed the coolant,and check for vacuum leaks.did you use a new TB gasket?get all the old gasket material off the head?torque the mani to the head at the proper value and sequence?
Chris
Chris
IlIkEg's
03-22-2006 06:55 PM
