high beam work but normal headlight does't work?
Old 12-13-2004, 03:07 AM
yeegsr's Avatar
Default high beam work but normal headlight does't work?
hmm....i can't find the symton
both of my headlights for some reason went out...but when i use highbeam and they work, but not normal headlights ...i tried to switch my other two light bulds and nothing happen....high beam work but normal doesn't....a
help please...
Old 12-13-2004, 03:37 AM
ironlung78's Avatar
Default Re: high beam work but normal headlight does't work? (yeegsr)
Check your fuses!!!
There are fuses for each individual light under the hood, and one main fuse under the dash.. Pull em out and check em out!!
Old 12-13-2004, 08:33 AM
hatchi's Avatar
low beam filament are burnt. did you check fuses for headlites?
Old 12-13-2004, 09:34 AM
TekSI's Avatar
Default Re: high beam work but normal headlight does't work? (hatchi)
https://honda-tech.com/zerothread?id=1076369
try suggestions there as well
Old 12-13-2004, 11:24 PM
yeegsr's Avatar
Default Re: high beam work but normal headlight does't work? (TekSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TekSI &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1076369
try suggestions there as well</TD></TR></TABLE>
thanx all....i'll do some read up on the link...and give you some update info 2morrow...my finals were over...thanx god...i got time to fix it now
Old 12-16-2004, 08:46 PM
Osek206's Avatar
^ This just happened to me tonight, I'm driving and I see one headlight is working and the other isen't. Then I drive alittle further and both headlights don't work. My highbeam works though. Anyone have any idea what I should do? I'm a newbie be all means. Can I drive with highbeams on just for a night? Will it drain my battery?
Old 12-16-2004, 08:49 PM
DAguyLS's Avatar
i know people who roll high beams all the time
why would it drain your battery. Do you know what an alternator is?
Old 12-16-2004, 09:14 PM
SC0TT's Avatar
Low beam is burnt out...
Old 12-16-2004, 09:21 PM
Osek206's Avatar
Default Re: (SC0TT)
Would that be the fuse or the bulb?
Old 12-16-2004, 09:24 PM
DAguyLS's Avatar
if your speaking of the low beam being burnt out then thats the bulb
invest in some silverstars, there bright as **** and not a pain in the pocketbook
Old 12-16-2004, 09:34 PM
31flavorscivic's Avatar
Default Re: (slamdLScivic)
Driving with your brights on is a good way to get a lifted chevy to back over you and make it look like an accident. I would just not drive for one night.
Old 12-16-2004, 09:36 PM
DAguyLS's Avatar
depends on how many rednecks are in your area...lol....j/k to all the rednecks out there
Old 12-17-2004, 10:10 AM
Osek206's Avatar
^up
Old 12-17-2004, 10:19 AM
jbscivichb92's Avatar
Default Re: (Osek206)
you wanna see rednecks, come out to jax raceway on a saturday night.
"yeeeee haaaaaaaaa, lets get on our **** kickers and kick some ****"
Old 12-17-2004, 10:37 AM
rasinhell's Avatar
replace the bulb. that same thing happened 2 me
Old 05-01-2005, 07:39 PM
yeegsr's Avatar
Default Re: (The-Beast)
bump this topic up again... NEW QUESTIONS
how can i differentiate a good fuse and a bad fuse by looking at it..?
baggedlude
02-24-2009 11:13 AM
Frstyl838
Lighting
02-09-2009 01:07 PM
jimboek
04-30-2007 05:22 AM
vdub08
07-24-2005 03:59 AM
Quick Reply: high beam work but normal headlight does't work?
