can't get timing right (searched)
Guest
Posts: n/a
i'm doing ingnition timing on a 95 VX, the dizzy was replaced about a month ago.
since thenit's been acting wierd, so i got out the timing light and checked it, it is fully advanced and it's at about 2 degrees BTDC, i took the bolts out ad turned it till it was at 16 degreees BTDC, there is no way i can get bolts in it, what's the deal, i checked the firing order, everything is the same besides the distributor, it's a remanufactured TD-42U.
Re: can't get timing right (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">seems like your cam timing is off by a tooth.</TD></TR></TABLE>
i agree. did you or someone recently do a timing belt or cam/gear install?
